Setting
Revision as of 13:04, 10 February 2023 by Frank@tygron.nl (talk | contribs)
Setting is an item that stores configuration properties of your project.
List of available settings
Name | Default value | Description |
ACTIVE_SCENARIO | 0 | Stores the id of the active scenario. |
AREA_GROUPS | Used to store Area attribute filters | |
AUTO_CALCULATION | true | Whether changes made to the project automatically trigger a recalculation of a project. |
BASE_PANELS | HOVER_PANEL NAVIGATION_PANEL TOPBAR_PANEL LEFT_MENU_PANEL FEEDBACK_PANEL | Panels that are considered base panels in the Template:User interface |
CAMERA_SPEED | NORMAL | |
CURRENCY | EURO | Currency that is used in your project. |
CUSTOM_DATA_SERVICE | My own CSW service | |
DECIMALS | 6 | |
DEFAULT_GROUNDPRICE_M2 | 400 | |
DEFAULT_GROUND_LOWER_PRICE_M3 | 50 | |
DEFAULT_GROUND_RAISE_PRICE_M3 | 50 | |
DETAILED | true | |
EXPORT_CRS | EPSG:3857 | |
GRID_CELL_SIZE_M | 2 | |
IMPORT_CRS | ||
IMPORT_CRS_FORCE_XY | true | |
LIMIT_MAP | MULTIPOLYGON EMPTY | |
MAP_SIZE_M | 0 0 | |
MAX_TOTAL_GRIDCELLS | 0 | Used to communicate the maximum amount of grid cells that your project can support. |
MEASUREMENT_SYSTEM_TYPE | SI | |
MIN_CELL_M | 0 | |
MODEL_STYLE | TEXTURED | |
PROJECT_NAME | Project Name | The Project's name |
RECALCULATION_REQUIRED | false | A setting that is set by the Tygron Platform to indicate this project required a recalculation. |
RECENT_CRSS | EPSG:3857 EPSG:28992 | |
REGION | NORTHWESTERN_EUROPE | |
RESERVED_LAND | MULTIPOLYGON EMPTY | |
SATELLITE_BRIGHTNESS | -1 | |
SATELLITE_COLOR | ||
SATELLITE_FILE_NAME | default | |
SCHEDULED_UPDATE | ||
SCHEDULED_UPDATE_MAIL | ||
SCHEDULED_UPDATE_SMS | ||
SDK_ACCESS | false | |
SECTOR_SIZE_M | 500 | |
SHOW_ACTION_LOG | true | |
SHOW_BUILDING_AND_MEASURE_POPUP | false | |
SHOW_WATER_POPUP | false | |
SKY_TYPE | DEFAULT | |
SOLAR_PANEL_POSITION | 0.0 -0.5 -1.0 | |
STATE | NOTHING | |
SUN_DATES | ||
SUPER_USER_MESSAGE | ||
SURROUNDING_MAP_EXTEND_M | 0 0 | |
TIMESTAMP_FORMAT | dd/MM HH:mm:ss | |
TIME_ZONE | ||
TRAFFIC_VISUAL_MULTIPLIER | 4.0 | |
WATER_HEIGHT | -20000.0 | |
WATER_TYPE | CANAL | |
WEB_ALLOW_LOGIC_EVENT | true | |
WEB_ALLOW_PARTICIPANT_EVENT | true | |
WEB_ALLOW_QUERIES | false | |
WEB_BASE_MAP | SATELLITE | |
WEB_FRONT_PANEL | -1 | |
WEB_MAP_CUSTOM_PANEL | -1 | |
WIND_DIRECTION | 135 | |
WIND_SPEED_M_PER_S | 5.0 | |
WIZARD_TIME_MINUTES | -1 | |
WORLD_REFERENCE_POINT | 0 0 |
