Log in
Please note: This page is currently being updated!
After reading this page
  • you've learned about the Tygron Engine log-in panel
  • you've learned how to log-in to the Tygron Engine with a Tygron account
  • you've learned how to log in with an email Invite Code
  • you've learned how you can select to automatically log in each time you start the application
  • you've learned how you can reset your lost password
Login Panel of the Tygron Engine web application
Go to www.tygronengine.com. The login screen appears.
In the Tygron Engine web application you need to login. After logging in you get access to the Tygron Engine and start editing your game. You need a user-name and a password before you can login.
Automatically logging in
If you need to login often on the same system, you can select to save your password. You should be aware, that if you select this option, anyone who accesses the Tygron Engine application on your computer, has access to your account and project(s) without having to enter your log-in credentials.
Lost Password
In case you lost your password, you can recover it by selecting the "Lost Password, click here to recover" link. When you enter your username, a new password will then be sent to your e-mail.
Log on to the Tygron Engine
Login with your Username and Password
How to log on:
  1. Goto http://www.tygronengine.com and login at with your username and password
  2. You will proceed to the main screen
