Camera
Revision as of 12:49, 7 February 2023 by Frank@tygron.nl (talk | contribs)
The Camera provides a particular view of project in the 3D Visualization. The user can choose between different camera modes. Each camera mode has a particular way of navigation controls attached to it.
Primary camera modes
There are several camera modes that you can select when navigating in the 3D Visualization: Standard, Top-down,Free. You can switch between these modes by clicking on the corresponding icon in the navigation panel.
Standard
This is the default camera mode. It provides different views based on the zoom level this camera is in. Close to the ground the camera is angled to provide a perspective in the 3D Visualization. When zooming out the camera will slowly settle into a cardinally-locked top-down perspective.
Left mouse button (hold)
Drag the camera along a flat plane, depending on the location the left mouse button was pressed.
Right mouse button (hold) or scroll wheel (hold)
Move the mouse left and right to rotate the camera around the upward axis defined by point the camera is currently looking at.
Move the mouse up and down to change the perspective angle. The perspective angle can be limited, depending on the zoom level of the camera.
Scroll wheel up-down
Zoom in and out one zoom level respectively.
Arrow keys
Move the camera in the direction of the arrow key used.
Space
Switch directly between a high and low perspective.
Top-down
This mode allows for an unskewed overview of spatial features at any zoom level.
Left mouse button
Drag the world side to side along a flat plane.
Right mouse button
Rotate the camera directly above point the camera is currently looking at, along the vertical axis extending from that point. Only works in the lower zoom levels.
Smoothly zoom in and out respectively.
Arrow keys
Space
Free
This mode allows for unlimited zooms and rotation.
Left mouse button
Right mouse button
Rotate the camera around the point the camera is currently looking at, along a spherical surface centered around that point.
Zoom in and out respectively in discrete steps.
Arrow keys
Walk mode
Walk mode can be activated by continuously zooming in when in either the Standard or Top-down camera mode.
W-key and S-key
Move forwards and backwards.
A-key and D-key
Turn left and right.
Space-key
Move the camera above or below the surface.
Automatic camera modes
Finally the automatic cameras
Cinematic
This camera mode is an automatic camera mode, which guides the user though the 3D Visualization of the project by flying from key-point to key-point of a predefined Cinematic. Optionally a text is presented to the user in the cinematic panel, which he/she can read and click to continue the cinematic. Optionally a user can skip this cinematic. This however has a consequence, potential events in upcoming key point s of a skipped cinematic will not be fired.
Space-key
Skip the cinematic.
Cinematic Edit Camera
A Cinematic is edited using a particular camera mode, which uses and visualizes a focus point. This focus point can also be moved around in the 3D Visualization. It has the following controls:
Left mouse button (hold) and move left or right
Rotates the camera around the focus point
Left mouse button (hold) and move forward or backward
Look down or move away from the focus point.
Move the focus point, base on the camera 's location.
Right and Left mouse button (hold together)
Move the camera up or down based on the focus point
Rotate the camera around the viewing axis defined by the camera and the focus point
Arrow keys Up and down
Arrow keys left and right
W-key and S-key
Move the camera and focus point forward and backwards.
A-key and D-key
Move the camera and focus point left and right.
Q-key and E-key
Rotate the camera and focus left and right
Z-key and X-key
Circling
This camera mode is an automatic camera mode, which rotates the camera around the center point of a planned action in the Future Design.
Moves the camera closer or further away from the planned action.
