Action
Revision as of 11:39, 14 August 2014 by Rudolf (talk | contribs)
After reading this page
  • You've learned what actions are
  • You've learned what categories are
  • You've learned how actions can influence indicators
  • You've learned how to add and remove actions to a stakeholder
File:Game overview.jpg
What is an Action
An action is an activity a Stakeholder can perform to achieve his objective. A typical example of an action would be a Housing Corporation aiming to realize social housing, or a Waterboard aiming to realize open water. Actions are tied to specific Stakeholders, referring to the capability each stakeholder has to influence the 3D World. For example the waterboard has the capability to realize Open water, but not social housing or roads.
How do actions relate to Tygron Engine
When a user plans an action it will influence the 3D World and have a certain effect on Indicators. The effect of the planned action simulates the effect the action would have in the real world. When a plants new trees, this action would have an effect on the indicator Quality of Life. Since a player can have different actions available to reach their targets, actions are organized into Categories.
What is a Category
A Category is a container grouping Actions and keeping them organized. Players have different actions available to reach their objectives on indicators, since many roads lead to Rome.
Effects of Actions on Indicators
Actions players take have an effect on indicators. Planning 8.100m2 of "Stadspark" in the Bedrijventerrein template (action), increases the Quality of Life indicator (effect) by 21.8%. The effect of the actions on indicators can be changed. For information about effects of actions see function values.
EditorEditor Menu bar → Stakeholders → Actions
What properties does a category have in the Tygron Engine?
All categories which have been added have a set of properties that can be adjusted.
Category Name
This Category name field is the name of the category. The Category name is displayed when a player hovers the mouse over a category. You can change the name of the category by editing the textfield.
Category Icon
The Category icon is a visual representation of a Category. The category icon is used to group several actions into. You can change the icon by clicking the Category icon and choosing an image from the list of images that appears.
Category Order
The category order defines the order in which the categories are being presented to the user. You can change the order by selecting a category and pressing Move up and Move Down. When finished press Apply.
Add / Remove Categories and Actions
Before an Action can be added to a stakeholder, a category needs to be created.
To add a category Right-Click the middle pane, and choose Add Category.
Add / Remove a category
To remove a category, select the category you want to remove Right-Click and select Delete from stakeholder
Add / remove an action to a category
To add an action to a category, drag an action from the left pane (for example, "Construction options -> Agriculture -> Corn Fields") to an available Category. When no category is available yet you need to to add a category first.
To remove an action from a category, select the action you want to remove from the category you want to remove, Right-Click and select "Delete Option"
Changing Actions
Available Actions
Predefined actions are available in Tygron Engine. Not all those actions have to be available to the players in all games. Available actions that the user can add to a category are divided in 3 different action groups.
Construction Options
Construction Options have actions defined which have to do with planning new constructions.
For more information on available Construction Options, read more about Functions, or see our exhaustive Function List
Agriculture
Agriculture contains actions related to agriculture: Floating crops, Farms, Corn Fields etc.
Dike
Dike contains actions related to special dikes: Basic Multidike, Dike with Parkinggarage, Dike with Trees, Dike with windmills, etc.
Education
Education contains actions related to educational buildings: Basis educational buildings, emergency classrooms, labs, primary schools etc.
Healthcare
Healthcare contains actions related to healthcare: Healthcare farm, Healthcare hotel, Hospital, etc.
Industry
Industry contains actions related to industrial buildings: Biorefinery, Silo's, Warehouses, Chimney, etc.
Leisure
Leisure
Top Market Housing
Top Market Housing
Nature
Nature
Market Housing
Market Housing
Offices
Offices
Other
Other
Parks
Parks
Squares
Squares
Roads
Roads
Senior Housing
Senior Housing
Shops and restaurants
Affordable housing
Affordable housing
Student Housing
Student Housing
Underground
Underground
Underground (with topside)
Extra Options
Extra options have all actions defined which have to do with transferring money, transferring property, or demolishing.
Demolish
Demolish
Finance
Finance
Inbox
Inbox
Land
Land
Sculpting
Sculpting
User Inputs
User Inputs
Upgrade Option
The Upgrade Options have all actions defined which deal with upgrading existing structures, renovating, green roofs, road upgrades.
Flat roof ->Green roofs
Flat roof ->Roofgardens
Flat roof ->Water roofs
Gardens -> Water tanks
Houses ->Renovate
Houses ->Renovate
Offices -> Apartments
Offices -> Shops
Offices -> Shops
Parkinglots -> Water-permeable
Roads ->High kerbstones
Roads ->Plant trees
Roads ->Plant trees
Roads ->U-Gutter
Roads ->U-Gutter
Roads ->Water-permeable
Solar Panels
Solar Panels
