Requirements
Revision as of 12:11, 27 January 2015 by Jurrian (talk | contribs)
System Specifications
Tygron products utilize gaming technology as their driving force, most notably the 3D visualization. This technology does mean a computer must meet certain requirements to be able to run Tygron products. Below the minimum system specifications.
Processor Intel Core i3 Processor (2.0GHz or more)
Memory 2 GB RAM memory or more
Graphics card * Has to support OpenGL 3.2 or higher, with a benchmark score exceeding 400. (This score can be found at videocardbenchmark.net or determined with the Tygron System Test software.)
Screen resolution 1024 x 768 pixels or higher
Operating system ** Windows 7, 8
Browser Google Chrome, Firefox or Internet Explorer 9 and higher versions that support Java Plugin version 8 and provide sufficient start-up rights.
* Note: The application can also run on systems with lower hardware specifications with a minimum of OpenGL 2.0 support for the video card. In the case of such systems, it has to be remembered that the End Users will experience lower visual quality and reduced stability. We can advise NVIDIA Geforce GT740 for desktop computers and NVIDIA Geforce GT740M for laptops (or better!).
** Note to Apple OSX users: we are experimenting with an OSX version, you are free to try it out however it is not officially supported.
Tygron System Test
To verify that a system is able to run the Tygron Engine, we have offer the System Test. This application will analyse the specifications of your computer, and provide you with a score to indicate how well your system will perform. The test requires that the software specification listed below are in order.
System Test
When the System Test returns scores of ‘MEDIUM’ or ‘HIGH’ then you are ready to go. ‘LOW’ will result in a sub optimal visualisation and for all other results we recommend that you checkout the Troubleshooting page.
Software Guide
Browser
Computers to be used with the Tygron Engine need to have some software (Browser and Java) installed. Please make sure the following are available on your system. Your browser must the most recent version of Microsoft Internet Explorer, Mozilla Firefox or Google Chrome. Your browser must also have Javascript enabled. This is enabled by default for most browsers.
Video card Drivers
Please make sure you have the latest drivers installed for your video card from the original manufacturer. Below a list of video card driver download locations:
Java
The Tygron Engine requires Java to function correctly. In general, we recommend the most recent version of Java. The latest supported version of Java is Template:Java version.
