How to check for errors when using the net validation panel
Revision as of 13:53, 7 October 2022 by Frank@tygron.nl (talk | contribs) (Created page with "The net validation panel will check the following for a given network type: * There is a root node * All net lines are connected directly or indirectly to the root node <!--* All net loads are connected via paths composed of net lines to the root note--> * All net nodes with only 1 net line connected to them have a net load connected to them * All net nodes with a net load connected to them only have 1 net line connected to them <!--* There are no cycles in the netwo...")
- There is a root node
- All net lines are connected directly or indirectly to the root node
- All net nodes with only 1 net line connected to them have a net load connected to them
- All net nodes with a net load connected to them only have 1 net line connected to them
You will also be able to "highlight" the network. This will highlight all segments of the network that are connected to the root node. All sections of the network that aren't connected in any way to the root node are not connected. This allows you to find small fractures which disconnect sections of the network.
