DXF
DXF is a file format to exchange CAD data from Autodesk. A DXF file is subdivided in several sections. The most important sections are:
- HEADER
- TABLES, containing definitions of layers
- ENTITIES: containing 2 and 3 dimensional shapes
- BLOCKS: containing 2 and 3 dimension shapes, reusable using INSERTS in ENTITIES.
ENTITIES
Currently, the following Autodesk CAD entity types are supported:
- LWPOLYLINES (2 dimensional line strings), including bulges. See also AutoCAD Documentation.
- LINE (single lines). See also AutoCAD Documentation.
- POLYLINE (3 dimensional line strings), currently only interpreted as 2 dimensional. The z-coordinate is ignored. See also AutoCAD Documentation.
- HATCH (polygonal data constructed using other boundary entities). See also AutoCAD Documentation.
- CIRCLE: full and partial circles, given a center point, radius and start and end angle. See also AutoCAD Documentation.
- ELLIPSE: full and partial ellipses, given a center point, major and minor axis, rotation and start and end angle. See also AutoCAD Documentation.
- ARC: curved lines given a center point and a radius. See also AutoCAD Documentation.
- VERTEX: 2 dimensional point. See also [AutoCAD Documentation].
- POINT: Same as vertex, but 3 dimensional. Currently only interpreted as 2 dimensional. The z-coordinate is ignored. See also [AutoCAD Documentation].
- SPLINE: 2 dimensional Control point splines are currently supported. See also [AutoCAD Documentation].
- INSERT: Predefined BLOCKS inserted at a point and with a rotation and a scale. See also [AutoCAD Documentation].
BLOCKS
BLOCKS are parts in a CAD drawing that can be reused multiple times by inserting them at different locations with optional alternative rotations and scales. The usage of BLOCKS in a DXF is supported.
