Net Cluster
Revision as of 14:07, 1 March 2022 by Frank@tygron.nl (talk | contribs) (Created page with "Net Cluster is an item that can group together one ore more Net Loads of multiple Net Types. Template panels can be applied to Net Clusters. Each individual Net Clus...")
Template panels can be applied to Net Clusters. Each individual Net Cluster Panel will show up in the project with an interact-able popup at the center location of the Net Cluster. This can be used to streamline user interaction with a large set of Net Loads.
Net Clusters can also be used to activate, deactivate and apply attributes to its linked-to Net Loads. Optionally a Net Type can be supplied, which will restrict the interaction to only the Net Loads of that Net Type.
