Template Project
This article is a stub.
After reading this page:
  • you've learned what a template is
  • you've learned about game templates in the Tygron Engine
  • you've learned about the available default game templates in the Tygron Engine
  • you've learned how to make a game template
  • you've learned how you can share your game template within your domain
What is a template
tem·plate noun \ˈtem-plət\
crafts: a shape or pattern that is cut out of a hard material (such as metal or plastic) and used to make the same shape and pattern in other pieces of material
computers : a computer document that has the basic format of something (such as a business letter, chart, graph, etc.) and that can be used many different times
general: something that is used as an example of how to do, make, or achieve something
From http://www.merriam-webster.com
Using templates in the Tygron Engine
In the Tygron engine it is possible to take the game elements only from an existing game - Stakeholders, Indicators, Actions, etc - and transpose these over to a new area. This is very convenient in case a similar spatial issue is at hand on different locations. This functionality also enables the user to make elaborate predefined actions or custom indicators, which can easily be transposed as a template game to another area.
Default templates in the Tygron Engine
There are two default games available in the Tygron Engine as templates: Climategame and Bedrijventerrein. Please select the linked names of these games for more information.
How to add your own template
Users can easily add their own game to the list of available template games.However, this can only be done by users with Domain Admin rights.
Sharing your template with other users in your domain
