Trigger
Revision as of 11:16, 8 December 2021 by Rudolf@tygron.nl (talk | contribs)
This article is a stub.
API Triggers can be used to execute external scripts and applications.
When an API Trigger executes, it sends a web request to a specified url. The web request includes query parameters which the receiving server can use to interact with the session from which the call originated.
Request
The following query parameters are relevant:
Type Key Meaning Notes
Querystring / GET parameter token API token for session access
Querystring / GET parameter f Expected return format. Defaults to "JSON"
Request header Referer The originating Tygron server "Referer" is misspelled in the original http specification.
Response
The web server is expected to send a response.
