Version 2021
Revision as of 11:20, 8 March 2021 by Godelief@tygron.com (talk | contribs) (Created page with "==Version 2021.0.0== {{:Version_2021.0.0}} ==Version 2021.1.0== {{:Version_2021.1.0}} ==Version 2021.2.0== {{:Version_2021.2.0}} ==Version 2021.2.1== {{:Version_2021.2.1}} ==V...")
Version 2021.0.0
Version 2021.0.0 is released on preview.tygron.com (Preview) on Friday April 17th 2020
Overlays
  • Increased grid to 2.000.000.000 cells and removed the cell limit on child overlays.
  • New watershed overlay as BETA.
  • Water overlay direction is now visualized with arrows.
  • New GeoJSON export option based on polygons using the legend values of a grid overlay.
  • Subsidence overlay can now also be calculated on (BRO) underground terrains.
TQL
  • Performance improvement for BUFFER in combination with a GRIDVALUE TQL query.
Other
  • New GPU architecture for improved performance, stability.
  • License usage is now synchronized with the LTS server.
  • Bugfix for Point Measurements when used on certain inactive overlays.
  • Removed old landmark functions.
  • Several smaller bug fixes.
Version 2021.1.0
Version 2021.1.0 is released on preview.tygron.com (Preview) on Monday May 4th 2020
Water
  • Improved version of the new Watershed Overlay.
  • Beta version for Culvert generator.
  • Fixed arrow visualisation in flow direction overlay.
  • Weirs, culverts that are very wide now have multiple input/output cells.
Other
Version 2021.2.0
Version 2021.2.0 is released on preview.tygron.com (Preview) on Friday May 29th 2020
Water
  • Improved version of Culvert generator.
  • Updated terrain infliltration and water retention values based on paper: Waterretentie- en doorlatendheids-karakteristieken van boven- en ondergronden in Nederland: de Staringreeks Update 2018.
  • Tweaked shoreline infiltration for infiltration only mode.
  • Updated road functions that are generally not sewered.
Other
  • BETA for Aerius Overlay.
Version 2021.2.1
Version 2021.2.1 is released on preview.tygron.com (Preview) on Friday June 16th 2020
Other
  • Updated Kadaster plot data to newest version.
  • Plots now use correct naming code.
Version 2021.3.0
Version 2021.3.0 is released on preview.tygron.com (Preview) on Friday June 26th 2020
Parametric Design
  • Option to generate a simple road pattern aligned to existing roads.
  • New functions: main road, road, sidewalk, parking, water and remainder.
Overlays
  • Added Aerius support for the emissions sectors: Wegverkeer, Wonen en werken, Plan and Mobiele werktuigen.
  • Added a wizard for the Aerius Overlay.
  • Crop damage overlay result types have been added to the Subsidence Overlay. The damage is calculated using the Waterwijzer Landbouw web-api.
  • Water overlays system view (showing Culverts, Inlets etc. ) now updates on changes to Buildings.
Attribute Actions
  • Attribute action is a new type of action which allows stakeholders so add or set attributes of Buildings directly by selection.
  • Attribute actions do not have construction time or construction costs associated with them, which makes them a simpler alternative to the Upgrade Type action on Buildings.
Panels
  • Template panels can now be applied to measures and also automatically applied in test runs.
  • Set maximum number of instanced Excels (used by instanced (Template) Excel Panels and Indicators) to 10 000 per project.
TQL
  • Added relation building and status to measure TQL.
Events
  • Set multiple attributes logic event has been added for Buildings.
Other
  • Implemented additional security measures for data protection.
  • Streamlined gml data services of project generation.
  • Updated plots data to use the new kadaster v4 data on nationaalgeoregister.
Version 2021.3.1
Version 2021.3.1 is released on preview.tygron.com (Preview) on July 3th 2020
Performance
  • Reduced Client memory footprint, resulting in better performance on low-end systems.
  • Limited amount of excels to 10.000 to prevent memory overload on server.
  • Action menu's are now shared by default for same type stakeholders.
Other
  • Text template panels update on changes to parent text.
  • Maintenance update windows will be announced several hours in advance.
  • Neighbourhood, Street and Global labels are better aligned.
Version 2021.3.2
Version 2021.3.2 is released on preview.tygron.com (Preview) on July 8th 2020
License Model
  • Allows for more new projects, only fair use on amount per day.
  • No longer limited by amount of saved projects only total area (km).
  • Fixed naming inconsistencies around license model.
GEO
  • Updated to different BAG service (old was no longer active).
  • Added new WaterWijzer Overlay accepting input from different Overlays.
2D Web Map
  • Display last time frame for Overlays instead of the first.
Other
  • Performance improvements in 3D rendering.
  • Reorganized the Overlays popup menu in the Editor.
Version 2021.4.0
Version 2021.4.0 is released on preview.tygron.com (Preview) on July 22th 2020
Water
  • Added support for groundwater seepage.
  • Increase time steps for weir heights and inlet Q from 100 -> 10.000.
  • Updated Waterwijzer Landbouw from version 1.1.0 to new 2.0.0 version.
GEO
  • Multi import of wizard object attributes using CSV.
  • CSV's can now contain Timestamps as time keys. The format can be configured in the Project's Settings.
  • Measurements can now be viewed in the Editor and imported/exported.
  • Most Items (buildings, areas, etc) can be exported using CSV.
  • Updated to latest JTS 17 Library for e.g. faster polygon intersection calculations.
  • Improved compatibility for different WFS server types.
TQL
  • Stricter name checking implemented.
  • Attribute names can no longer start with a digit or XML.
  • INDEX_X now returns 100 indices.
Other
  • Experimental Travel Distance Overlay.
  • Small improvements to Aerius Overlay's results
Version 2021.5.0
Version 2021.5.0 is released on preview.tygron.com (Preview) on Sept 1 2020
Water
  • Small improvement to calculation speed.
  • More detailed building storage.
  • Building storage result type.
  • Corrected the Seepage formula to correctly calculate the seepage amount.
GEO
  • Updated to new BGT standard.
  • Import/export of net items now support crs's other than EPSG:3587 Web Mercator.
  • Fixed Arcgis Pro WFS services.
Excel
  • Improved excelsheet loading.
Other
Version 2021.5.1
Version 2021.5.1 is released on preview.tygron.com (Preview) on Sept 8th 2020
Water
  • Timeframes can have custom timestamps (e.g. at non-linear intervals).
GEO
  • Option to limit the amount of project data loaded at geo selection.
  • Support for xllcenter and yllcenter in Esri ASCII files.
  • The plot owner is now by default also the building owner.
Other
  • Improved error handling for invalid data in imported networks.
  • Improved error handling for failing WFS servers.
  • Fix for building surface heights in Geo Wizard.
  • Fix for invalid addresses in BAG.
  • Fixed error in API for logs retrieval.
Version 2021.5.2
Version 2021.5.2 is released on preview.tygron.com (Preview) on Sept 9th 2020
GEO
  • Improve world wide address searching in project area selection panel.
  • Fix specific CRS bug in I3S loading.
Water
  • New result type that shows the water level as datum (dutch: NAP waarde).
Other
  • Improved is active checking in Excel calculations for Areas.
Version 2021.5.3
Version 2021.5.3 is released on preview.tygron.com (Preview) on Sept 21th 2020
Geo
  • Addresses are now separate objects in the API with attributes.
  • Addresses contain the original BAG identification as an attribute and function type as value.
  • Improved the stability of the new BGT-connector introduced earlier this month.
Water
  • New GPU Architecture based on CUDA Graphs, resulting in ~20% calculation time reduction.
  • Invalid water objects have a "object flow" attribute value of NO_DATA (~ -3.4+e38) for easy exporting/debugging.
Other
  • Small fix for incorrect source referencing in BGT terrains.
Version 2021.6.0
Version 2021.6.0 is released on preview.tygron.com (Preview) on Oct 8th 2020
GEO
  • New Parametric Design implementation based on percentages.
  • Warning: Incompatible with old designs, please remove them.
Water
  • Support for rectangular shaped culverts.
  • Result Types GROUND_LAST_STORAGE and GROUND_MAX_STORAGE now include both saturated and unsaturated groundwater.
Other
  • Updated to latest Dutch Crop Codes.
Version 2021.7.0
Version 2021.7.0 is released on preview.tygron.com (Preview) on Nov 10th 2020
Parametric Design
  • Water is now always between roads.
  • Several smaller improvements to algorithm.
Water
  • Grid Averaging is a new option to calculate surface water in e.g. groundwater simulations. No impulse, but much faster.
  • Underground inlet areas. These can be used to simulate an underground pump or setting a groundwater border.
  • Impacted Buildings Overlay is now per time frame and includes a range attribute to set the amount of effected cells.
Other
Version 2021.7.1
Version 2021.7.1 is released on preview.tygron.com (Preview) on Nov 13th 2020
GEO
  • New Solar Panel visualizations via SOLAR_PANEL attribute.
  • New ALIGN_ELEVATION attribute that can be used to make buildings float or align to (uneven) surface.
  • Attribute Action updates now also get visualized in test runs (e.g. change roof color attribute).
  • Added Windmills from BGT on new project generation
Aerius
  • New button that downloads the latest results.
Parametric Design
  • Improved road alignment.
Water
  • Improved Grid Averaging Areas.
Other
  • Fixed issue with invalid addresses.
  • Fixed invalid Open Street Maps data.
  • Fixed several missing icons.
Version 2021.7.2
Version 2021.7.2 is released on preview.tygron.com (Preview) on November 27th 2020
Aerius
  • Update Aerius to latest 2020 version.
Compatibility
  • Improved support and compatibility for AMD (ATI) Video cards.
  • Support for latest Video cards.
Other
  • Fixed bug in Travel Distance Overlay.
Version 2021.8.0
Version 2021.8.0 is released on preview.tygron.com (Preview) on Dec 3rd 2020
Combo Overlay
  • New Combo Overlay that can combine results from up to 3 grid overlays.
  • Combo supports all basic operators (e.g. add, max, avg, sqrt, less than, equals).
  • The Average, WWL and Watershed Overlays support Combo Overlays as input.
  • Combo supports timeframes and Globals.
Water
  • Rainfall can now be configured as areas distributed over the project area. Up to 100 areas are supported, allowing e.g. moving rain showers.
  • Transpiration of plants has been improved, by using the Feddes Trapezium instead of a single root depth value.
  • Drainage systems (with or without active pumping) have been added.
  • New result types: groundwater direction, groundwater flow and rainfall.
  • Improved Water wizard icons, text and underground inlet feedback.
  • Improved calculation speed for small maps with timeframes.
  • Substances have been renamed to "tracers"
  • Adjusted the Functions step in the wizard
Other
  • New floating solar panel models
  • Option to delete all Areas belonging to a filter.
Version 2021.8.1
Version 2021.8.1 is released on preview.tygron.com (Preview) on Dec 18th 2020
GPU Calculations
  • Scheduled long running calculations can now also be triggered during office hours.
  • Regular short updates are limited to half an hour.
Water
  • Bridges and floating buildings are now optional in the elevation model via advanced settings.
  • Added option to specify the hydraulic conductivity for the underground terrains.
Other
  • Several maintenance updates to underlying architecture.
  • Updated client installer with latest security updates.
Version 2021.8.2
Version 2021.8.2 is released on preview.tygron.com (Preview) on Dec 21th 2020
Access
  • All new Preview features (see WIKI) are now available to all users.
  • API access is now available to all users.
Water
  • Added new LAST_RAIN result.
  • Added warning for hydraulic structures without an geometry.
Other
  • Reduced memory usage of server application.
  • Recalculation required now correctly showing for added result children.
  • Fixed raising land using the Raise Land option
Version 2021.8.3
Version 2021.8.3 is released on preview.tygron.com (Preview) on Jan 8th 2021
GPU Architecture
  • Update to latest GPU Architecture (CUDA 11.2).
  • Several improvements resulting in faster Overlay updates. E.g. Heat Overlay is 40% faster.
I3S Models
  • Added option to use I3D Model height or relative to terrain.
  • Fixed a crash when using deprecated shared textures.
  • Improved compatibility for different I3S Texture types.
  • Known Issue: Wrap mode: repeat is not supported in atlas textures.
Other
  • Improved AMD Ryzen support.
  • Updated the SSL Certificate.
Version 2021.8.4
Version 2021.8.4 is released on preview.tygron.com (Preview) on Jan 15th 2021
TQL
  • Added support for Y Query, allowing TQL labels in excels to go both per row and column.
  • Attributes can now also be queried per time frame. E.g. weir buildings values in water overlay.
API
  • Added multiple endpoints to Editor Interface.
  • Added hints for events parameters.
  • Improved API overview / styling.
  • Removed support for deprecated api/services directory.
  • All Items (e.g. buildings, areas) now have their ID visible in the Editor Interface.
Water
  • Added advanced setting to adjust the generated dam with of a weir.
  • Bugfix for non square maps with seepage active.
Other
  • Option to trigger a scheduled update (with SMS) from ribbon bar.
  • Area filter is now called Group By.
  • Improved CPU detection during start-up.
  • Added cinematic control with keyboard arrows.
  • Fixed issue with difference overlay legend.
  • Updated several texts and icons.
Version 2021.8.5
Version 2021.8.5 is released on preview.tygron.com (Preview) on Jan 22th 2021
Water
  • Flow per timeframe in Breaches and Sewers are now stored as Area attribute.
  • Flow in objects (breaches, weirs, etc) can now also be visualised/exported in the measurement tool.
  • Improved performance of large import events (e.g. 500K Infoworks triangles as Areas).
Parametric
  • Added option to save design as Measure.
Subsidence
  • Added option to set start year & temperature.
Solar Panels
  • Can now be positioned on the roof (e.g. north, south, etc).
API
  • SMILE and ZIPSMILE are no longer typed (special format used internal).
  • Typed JSON is no longer listed in API.
  • Improved API import of buildings, areas, terrains, etc.
Other
  • Bugfix for Sub Domain project size.
  • Bugfix for invalid Y Query.
  • Kill session now also kills long running events (e.g. importing 100k+ buildings).
Version 2021.8.6
Version 2021.8.6 is released on preview.tygron.com (Preview) on Jan 29th 2021
Timeframes
  • For consistency: Timeframes in API, TQL, Combo, export panel and the viewer always start from ID=0 instead of ID=1.
  • WARNING: Existing Combo Overlays with a frame number in the formula must be lowered, e.g. A1 -> A0.
  • TIMFRAME_IS_X and -_IS_Y queries are now also supported for GRID_WITH_ATTRIBUTE_IS clauses
Overlays
  • Improved rendering speed of Overlays with multiple timeframes resulting in smoother movies.
  • Overlay legend displays the frame number and timestamp.
  • Improved WMS performance.
Parametric Design
  • Improved result generation for smaller areas.
  • Improved "save as measure" speed.
  • Added option to ignore existing buildings.
  • Existing buildings are removed when applying the design.
  • Improved water land extrusion.
  • Added the Floor Space Index, Ground Space Index and Open Space Ratio.
Other
  • The risk assessment (risicokaart.nl) is down for long term maintenance, option is disabled by default.
  • Added more documentation to API and disabled invalid API formats.
  • Fixed issue with culvert visualization.
  • Fixed connection issue with Beamer app.
  • Fixed an issue in the I3S import process
Version 2021.8.7
Version 2021.8.7 is released on preview.tygron.com (Preview) on Feb 5th 2021
TQL
  • Added X-Query for existing (pre testrun) buildings.
  • Limited X-Query to 64K rows and Y-Query to 16K columns.
  • Bugfix for update query building with specific ID.
Geo
  • Improved open land mapping.
  • Bugfix for I3S import in measures.
Water
  • Support more overlays for Weather flood visualization.
  • Improved caching and renders peed of Weather visualization.
  • Add min/max elevation map as advanced option.
  • Bugfix for changing water structures that resulted in errors.
  • Wateroverlay feedback on custom timeframes and CSV title recognition.
API
  • Renamed gameName to projectName in API Logs.
  • Duplicate events return new item ids.
  • Improved response codes/errors of API.
Other
  • Added progress bar to Overlay legend panel.
  • Bugfix in Item Measurement overlay selection.
  • Bugfix for excel download issues.
Version 2021.8.8
Version 2021.8.8 is released on preview.tygron.com (Preview) on Feb 12th 2021
Subsidence
  • Added timeframe support to Subsidence Overlay.
  • Added the option to set the simulation start year.
  • Added more configurable Climate model parameters to the wizard.
  • Added feedback about the Climate model
  • Improved subsidence WIKI pages.
  • Limited max subsidence to top layer * peat fraction.
API
  • Added extra logging of user activity (e.g. add/remove user) for domain admins.
  • Added extra logging of security incidents (e.g. false password login) for domain admins.
  • API endpoint for session logging has moved: /api/logs/mydomain/ -> /api/logs/sessions/.
  • Bugfix for concurrent modifications in API calls.
Performance
  • Improved client performance when executing large Measures.
  • Improved client performance for large/complex building polygons.
  • Improved server memory handling, allowing more projects active.
Other
  • Added new 3D models for (electricity) transmission towers.
  • Improved geo mapping of open land.
  • Bugfix for loop in Prequel Overlays.
  • Bugfix for height map issues at sea.
  • Bugfix in Measure levees.
Version 2021.8.9
Version 2021.8.9 is released on preview.tygron.com (Preview) on Feb 19th 2021
Parametric Design
  • Improved layout of bottom feedback panel.
  • Bugfix for specific use-cases.
Subsidence
  • Added timeframes and years per timeframe to subsidence overlay.
  • Improve area configuration in the subsidence wizard.
  • Added configuration of all climate parameters and start year of subsidence.
  • Clay thickness can alternatively be configured using a geotiff.
  • Fixed issues with ground water level calculation.
  • The maximum subsidence is now limited to the amount of peat in the top layer.
  • Updated and improved the documentation on subsidence.
Water
  • Added tracer support for drainages.
  • Added tracer support for surface mode: grid averaging waterways.
Performance & Limits
  • Reduced maximum amount of excels to 1000.
  • Added warning when project contains more then 25.000.000.000 grid cells in total.
  • Total grid cell amount can be viewed in calculation pop-up.
  • Improved memory handling of large projects.
Other
  • Windmills have label Tower height instead of just height for more clarity.
  • Enabled shadows on low-end systems.
  • Travel distance, only selecting routing area when attribute > 0.
Version 2021.8.10
Version 2021.8.10 is released on preview.tygron.com (Preview) on Feb 26th 2021
Underground
  • Extended 3D visualization to also go below the surface.
  • Go below surface by zooming in, hitting space when walking or using the free cam / cinematic.
  • Added new basement depth for all buildings.
  • Network Distance Overlay: vertical distance between net lines and basements, roots and underground buildings.
  • Net lines now also support a Z (height) coordinate when importing & drawing (using depth variable).
  • Both distance zone and avg overlays support net lines.
  • New button in top-right navigation bar to make the surface transparent.
Combo
  • When selecting an overlay as just "A" the lat time frame is selected by default. Consistent with TQL.
Geo
  • BGT transmission towers with Top10nl power lines (beta).
  • Metro lines are loaded as underground & surface buildings.
  • DEM is by default 1m resolution now.
  • Improved address search bar in navigation panel.
Other
  • Updated end user conditions for API access for all users.
  • Improved camera zooming behavior.
  • Bugfix for specific parametric design cases.
  • Bugfix for importing I3S models.
  • Bugfix for buying/selling land.
  • Bugfix for parked cars visualization.
  • Several fixes in wizards (icons, texts, bugs).
Version 2021.9.0
Version 2021.9.0 is released on engine.tygron.com (LTS) on March 5th 2021
This is the major update of the LTS for 2021.
Water
  • New Watershed Overlay.
  • Support for wider river weirs and inlets.
  • New avg super-grid model for groundwater.
  • Culvert Generator.
  • Waterwijzer Landbouw overlay.
  • Distributed Rainfall.
  • Other: drains, seepage and arrow visuals.
Geo
  • Improved SLPK support.
  • Underground visualization.
  • Improved Parametric Design visuals and options.
  • Transmission towers and power lines.
Developers
  • API access for all users.
  • New Combo Overlay that can combine overlay results.
Other
  • Solar panels visualizations.
  • Multiple bug fixes and performance improvements.
