Chart (Parametric Design)
Pie chart
The pie chart provides information on the generated Parametric Design. The following information is given from the left column to the right:
  • The percentages that were set with the sliders in the Design tab. Behind the dots, the percentage of the function that actually fits in the generated design is shown.
  • In the darker grey column, the area per function is given in m2 or hectare, dependent on the size of the selected design area. At the top of this column, the total size of the design area is given.
  • The Functions that were chosen in the Funcion tab. For the Building function the floor space is provided between brackets and for the road function the division in road and pavement is added.
  • In the next column, for the Building function type the amount of units in the design and between brackets the Building area in m2 is provided.
  • In the last darker grey column, for the Buildig function the units/hectare are shown. Also the Floor Space Index, Ground Space Index and Open Space Ratio are calculated. For the public green and garden functions the area per function/ unit is calculated. For the parking function, the amount of parking spaces per units are calculated. The size of a parking space can be adjusted in the Plot tab
The pie chart with more information about the parametric design
  • The percentages shown in red indicate that the set percentages with the sliders could not be met and are therefore changed to the best fitting percentage per function for this area with these parameters.
  • In the pie chart, undeveloped land is listed as Remainder.
  • For Buildings, the amount of units, the units per hectare and the average floor area of the buildings is provided.
  • For Public Green and Gardens, the area size per unit is given.
  • For Parking, the amount of parking spaces per unit is given. The size of a parking space can be set with the parameters in the Road tab.
