Maptype postfix (Excel)
Revision as of 15:38, 3 March 2021 by Rudolf@tygron.nl (talk | contribs) (Created page with "framed|right|The name of this cell is appended with <code>_CURRENT</code>, and the other with <code>_MAQUETTE</code>. Non-query output cells use a word...")
Non-query output cells use a word or phrase to indicate that the value should be output in some fashion. By default these values are used for both the current and maquette views in the Tygron Platform. However, sometimes it may be desirable to output different scores for the current state and the maquette state of the project. One such situation is when the Simulation Type of the project is set to timeline.
In these cases, the cell names can be expanded by adding a _CURRENT or _MAQUETTE to the name of the cell. Both will need to exist to make the Excel file valid.
This functionality does not extend to query (output) cells. For input cells, a switch between map views is possible via a built-in clause.
