Version 2021.8.9
Revision as of 20:13, 19 February 2021 by Maxim@tygron.com (talk | contribs)
Version 2021.8.9 is released on preview.tygron.com (Preview) on Feb 19th 2021
Parametric Design
  • Improved layout of bottom feedback panel.
  • Bugfix for specific use-cases.
Subsidence
  • Added timeframes and years per timeframe to subsidence overlay.
  • Improve area configuration in the subsidence wizard.
  • Added configuration of all climate parameters and start year of subsidence.
  • Clay thickness can alternatively be configured using a geotiff.
  • Fixed issues with ground water level calculation.
  • The maximum subsidence is now limited to the amount of peat in the top layer.
  • Updated and improved the documentation on subsidence.
Water
  • Added tracer support for drainages.
  • Added tracer support for surface mode: grid averaging waterways.
Performance & Limits
  • Reduced maximum amount of excels to 1000.
  • Added warning when project contains more then 25.000.000.000 grid cells in total.
  • Total grid cell amount can be viewed in calculation pop-up.
  • Improved memory handling of large projects.
Other
  • Windmills have label Tower height instead of just height for more clarity.
  • Enabled shadows on low-end systems.
  • Travel distance, only selecting routing area when attribute > 0.
  • Several smaller bug fixes.
