Account management
Revision as of 11:10, 17 October 2014 by Vincent (talk | contribs) (→Invite Only)
This article is a stub.
After reading this page:
  • you've learned about user account management
  • you've learned about the different account types in the Tygron Engine
  • you've learned how accounts relate to their domain
  • you've learned about the different license types
  • you've learned how to change user account details
User Account management
User management is the process that focuses on the administration of users of IT and information systems. This process manages the registration of users and the authorisation of their roles within a system. Authorised access is secured with a user specific login name and password.
User Management can control, for example:
  • The projects a user can access
  • Whether access to that project is read-only
  • If a user can update his credentials (login, password)
  • If a user can update relevant project data
  • If a user can host or join a session with other users
Different account types in the Tygron Web Application
The Tygron Web Application uses account management to enable user access to their proper projects, and with the required rights to perform the actions desired. To ensure that users have access to their assigned projects, and their assigned projects only, users are grouped in so called user domain groups (="domain"). Within a domain, users can have different roles, or account types, assigned. These types or roles determine the actions a user can perform within his domain. These different account types are described below:
Invite Only
The Invite Only account type is the account type with the lowest access level. When using this type, the user can only be invited to a session. The user can only perform a minimum of actions, such as:
  • Run the hardware benchmark test
  • Call up online support resources, such as the Wiki and Forum
  • Log out of the tygron Web Application
Single Player
Multiplayer
Editor
Group Admin
Account Type Description Available options
in main menu
INVITE_ONLY This account can only be invited to a multi player session Invite only
SINGLEPLAYER This account can only access Demo and Single Player games Singleplayer
MULTIPLAYER This account can start and join multiplayer sessions, including the inviting of INVITE_ONLY accounts Multiplayer
EDITOR This account type can, besides hosting and playing multiplayer games, create and edit its own games Editor
GROUP_ADMIN This account is the highest access level available to users. With this account you can also manage other accounts from your user group. Group Admin
User accounts are grouped under a domain
User Domain Groups
User license types
Changing user account and user domain details
