How to edit the Camera Position
Revision as of 10:26, 9 February 2021 by Reijn@tygron.com (talk | contribs) (Created page with " frame|right|The buttons in camera editing mode. When the "Edit Camera Position" button is selected, you enter camera editi...")
When the "Edit Camera Position" button is selected, you enter camera editing mode. This mode allows you to edit the camera location and orientation for the selected keypoint. In place of the "Edit Camera Position" button, new buttons will have appeared in the right panel to store the current camera position. In the 3D world, an object will be visible to help orient the camera.
Moving the Camera
This object indicates where the camera is currently aimed at.
While editing the camera position for a cinematic, you have more exact control over the camera. This also means the controls are different from moving the camera normally.
Template:Editor steps
Store Camera Position
The button to store camera position.
When the camera is in the position you want for this keypoint, you can press "Store Camera Position" to store the current location and orientation of the camera for this keypoint.
Stop Editing Camera Position
The button stop editing the camera position.
When you are done editing the camera position for this keypoint, you can press "Stop Editing Camera Position" to leave the camera editing mode. The camera will reset to the camera position set for this keypoint. If you store your current camera position right before stopping camera editing mode, you will not see the camera move.
