Brp code (Waterwijzer Overlay)
Revision as of 10:15, 6 October 2020 by Rudolf@tygron.nl (talk | contribs)
Icon | Key | Unit | Range | Description | Default value |
BRP Code | none | Dutch agricultural identification code | n/a |
- This parameter is obtained from the Buildings. Projects generated using the Basisregistratie gewaspercelen geoplugin (BRP) will have this parameter set for the agricultural land use.
- The Waterwijzer tool's API uses this code directly. However, the online tool combines a number of categories together, resulting in a smaller selectable range[1].
- Possible values for BRP_CODE
- ↑ Koppeltabel landgebruik, https://waterwijzerlandbouw.wur.nl/downloads/VertalingGewassen-1.1.0.pdf, last visited on 31-8-2020
