How to manually adjust Indicators in Excel
Revision as of 13:41, 10 September 2020 by Reijn@tygron.com (talk | contribs)
How to manually adjust Indicators in Excel:
- Go to Current Situation -> Indicators, "Add" a new Excel indicator in the bottom left corner
- "Select Excel sheet" (in the middle right of the screen) of the desired new indicator (downloaded from the Tygron Index)
- Import the new Excelsheet
- Index should be visible in the indicator grid
- Update platform
- Press Debug Excel sheet
- Save Debugged Excelsheet with desired name
- Open this file in Excel
- Adjust the values in the column with the desired values (e.g. targets for each neighborhood) and save the file
- Go back to the Tygron platform and press "select Excelsheet" again and "import" or update the saved Excelsheet
