How to manually adjust Indicators in Excel
Revision as of 13:37, 10 September 2020 by Reijn@tygron.com (talk | contribs)
How to manually adjust Indicators in Excel:
  1. Go to Current Situation -> Indicators, Add a new Excel indicator in the bottom left corner
  2. Select Excel sheet (in the middle right of the screen) of the desired new indicator (downloaded from the Tygron Index)
  3. Import the new Excelsheet
  4. Index should be visible in the indicator grid
  5. Update platform
  6. Press Debug Excel sheet
  7. Save Debugged Excelsheet with desired name
  8. Open this file in Excel
  9. Adjust the values in the column with the desired value (e.g. targets for each neighborhood) and save the file
  10. Go back to the Tygron platform and press select Excelsheet again and import or update the saved Excelsheet
