Aerius Module benchmarks
Revision as of 09:55, 10 August 2020 by Godelief@tygron.com (talk | contribs) (Created page with "In order to compare the results of the {{software}} connection with the Aerius Calculator with the results from the [https://calculator.aerius.nl/calculator/?locale=nl# Aerius...")
In order to compare the results of the Tygron Platform connection with the Aerius Calculator with the results from the Aerius Calculator, a fictional test case is conducted. See the link below for the results:
