Template:Water Overlay height warning
Revision as of 08:26, 22 June 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "====The {{{name|{{{attribute|parameter}}}}}} is (much) higher than the average land height==== The {{linkappend|post= (Water Overlay)|{{{attribute|attribute}}}}} is much...")
The parameter is (much) higher than the average land height
The attribute is much higher than the average terrain height, which likely means an improper value has been imported as attribute. The effect in the model is undefined.
To resolve: Ensure that the configured attribute is not set to a placeholder value. Note that if the attribute is indeed correct but the warning persists, the warning can be ignored.
The parameter is (much) lower than the average land height
The attribute is much lower than the average terrain height, which likely means an improper value has been imported as attribute. The effect in the model is undefined.
To resolve: Ensure that the configured attribute is not set to a placeholder value. Note that if the attribute is indeed correct but the warning persists, the warning can be ignored. Parameters:
- attribute: The attribute causing the issue
- name: The name of the parameter (human-readable version of the attribute)
- effect-high: The effect of having this attribute configured too high
- effect-low: The effect of having this attribute too low
