Traffic Model
What is a Traffic Model
The main purpose of the default traffic model in the Tygron Platform is to calculate the effects of traffic on the 3D World through traffic densities. In order to calculate this impact, data such as the number of traffic lanes, the traffic speed and the traffic flow on a particular lane can be added to the project. The traffic model is a static model that does not change by carrying out Actions, Upgrades or Measures for example. Read below how to create your own dynamic traffic model and use it in the Tygron Platform. The following overlays show data from/effects of the traffic model:
Traffic Data
When creating a new project a traffic model is generated for the selected project area, based on available open data sources. The following datasets are used:
Edit Traffic data
File:Traffic data.jpg
The right panel shows details about the selected road part
Height offset
This field specifies the height offset of a bridge.
Units per hour
This field specifies the number of units that can drive on a road in an hour.
Lanes
This field specifies the number of lanes that a road can have.
Noise Sigma
This field specifies the correction factor at reference traffic speed [1].
This value is used in the calculation of the Traffic Noise (Overlay).
Noise Tau
This field specifies the correction factor per 10 km/hour deviation from reference traffic speed [2].
Speedlimit
This field specifies the max allowed speedlimit on road or part of a road.
Add a custom Traffic Model
Create GeoJSON File
How to create a GeoJson file in QGis:
  1. Open QGis
  2. Select the Layer tab
  3. Select 'Add Layer' in the Layer tab
  4. Select 'Add Vector Layer' in the dropdown menu
  5. Choose the file you wish to add and select 'Open'
  6. Notice that the file appeared in the Layers Panel
  7. Select the newly added file and choose 'Save As'
  8. Notice that a new window with options has appeared
  9. In the 'Format' field choose 'GeoJSON'
  10. In the 'Name' field enter a name for the file
  11. In the 'CRS' field choose the right CRS for the file
  12. Select 'Ok' to create and save the GeoJSON file
  13. Notice that the newly created GeoJSON file is added in the Layers Panel
