Requirements
System Specifications
Tygron products utilize gaming technology as their driving force, most notably the 3D visualization. This technology does mean a computer must meet certain requirements to be able to run Tygron products. Your hardware is automatically categorized into the following scores. The total score of your computer is based on the lowest scoring component, and will affect both the default graphical settings and the ability to load in larger project areas.
CPU (Processor) Memory (RAM) GPU (Videocard)* Recommended system Notes on score
LOW Celeron At least 4GB RAM Benchmark score below 1000
with OpenGL 4.0, GLSL 400
Systems with this score are not fully supported. Graphical issues and slow responses can be expected.
MEDIUM AMD Athlon
Core 2
Pentium
At least 8GB RAM Benchmark score above 1000 HP Omen Desktop 870-242nd
This model is currently in active use at Tygron.
This is the minimum recommended score. For creating and opening projects with a map greater than 10x10km, at least MEDIUM is required.
HIGH i3, i5 At least 16GB RAM Benchmark score above 1500+
EXTREME i7 At least 32GB RAM Benchmark score above 5000
* We have found that NVIDIA cards provide the best stability in comparison to Intel and AMD. Therefore, we can strongly advise NVIDIA Geforce GT1050 for desktop computers and NVIDIA Geforce GT1050M for laptops (or better). We recommend looking for cards in the high-end consumer segment (GeForce), as the Tygron Platform does not make use of the extreme-precision capabilities of the more expensive Quadro cards.
Screen resolution 1280 x 800 pixels or higher
Operating system Windows 8, 10 (64 bit)
Internet connection ** Required
** There are no specific requirements to the internet connection. However, we advise to test the performance and connectivity of the available connection when preparing for a session.
Virtualization
Virtual environments are currently not supported. The Tygron Platform's 3D visualization is one of its basic functionalities. To properly render a 3D environment as performant as possible, the software requires being run on a physical computer. Virtualization software (such as Citrix or VMware) is currently not supported, because the speed of 3D rendering is significantly reduced by virtualization, which abstracts direct access to the GPU, slowing the process of rendering the 3D environment.
Software Guide
Video card Drivers
Please make sure you have the latest drivers installed for your video card from the original manufacturer. Below a list of video card driver download locations:
Browsers
  • Google Chrome
  • Mozilla Firefox
  • Opera
Explanation
Hardware
Because the Tygron Platform is 3D visualization software, the various hardware requirements list above must all be met. A brief clarification of why each requirement is relevant:
CPU
The processor is the general "computing" part of a computer, performing most functions of a computer. General responsiveness of the application and the computer itself are dictated by the processor.
RAM
GPU
Often in the form of a videocard, the graphical processor deals with all visualization matters. This component makes the 3D visualization of the Tygron Platform possible.
Screen resolution
The Tygron Platform is a complex tool, and require sufficient screen space to allow an overview of all options and information panels.
Internet connection
The core technology of the Tygron Platform is cloud-based. Your computer needs to be able to visualize the application and keep data about the project available, but the really heavy lifting in terms of calculations is done in the cloud. This means you need to be connected to the internet, and the better your internet connection the more responsive the application will be when dealing with data updates.
Software
The ability to support the use of specific software can be based on a variety of decision. A brief clarification on the supported software:
Browser
At the time of writing, Microsoft's Internet Explorer is only available on Windows for legacy reasons, and Microsoft is actively encouraging users to switch to more modern browsers. Additionally, Microsoft's Edge is not fully supported.
