How to create a parametric design
Revision as of 10:49, 8 January 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "{{stub}} {{howto|title=create and use a parametric design| | Create a new parametric design. | Select the desired design type. | Select the desired function. | Select the desi...")
This article is a stub.
How to create and use a parametric design:
  1. Create a new parametric design.
  2. Select the desired design type.
  3. Select the desired function.
  4. Select the desired floors.
  5. Draw the extent in the 3D world.
  6. Set the desired surface area and distance. Balance them.
  7. Verify that the selections in the 3D world look appropriate. If not, tweak the configuration further.
  8. Apply the design.
  9. Verify that the result looks appropriate. If not, revert the application and tweak the configuration further.
