Heat Module benchmarks
This page describes benchmarks performed for the Heat Stress Module.
The performed benchmark has an average difference below 0.70% for the selected measurement points.
Introduction
This benchmark case is situated on 02-08-2013 and is included in the DPRA Heat stress report. It is deemed relevant to the report because it can be related to actual measurements made for the city of Wageningen. PET measurements for this exceptionally hot day are comparable to the 01-07-2015 PET measurements for Wageningen.
Results
The PET Benchmark result overlays can be seen below:
Point Measurement Analysis
Several points have been compared for results. These points across the map have been selected based on fact that their spatial situation (i.e. input data like foliage and vegetation fraction) is similar for both the Wageningen calculated PET and Tygron generated PET.
| id | Wageningen PET | Tygron PET | Difference (%) |
| 01 | 46.12 | 46.13 | 0.022 |
| 02 | 47.44 | 48.04 | 1.26 |
| 03 | 47.11 | 47.52 | 0.87 |
| 04 | 44.70 | 44.99 | 0.65 |
| 05 | 40.53 | 40.48 | -0.12 |
| 06 | 38.69 | 38.67 | -0.05 |
| 07 | 42.52 | 42.45 | -0.16 |
| 08 | 44.87 | 44.03 | -1.87 |
| 09 | 43.62 | 43.02 | -1.38 |
| 10 | 46.79 | 46.58 | -0.45 |
| 11 | 38.70 | 38.79 | 0.23 |
| 12 | 44.40 | 44.00 | -0.90 |
| 13 | 46.34 | 46.29 | -0.11 |
| 14 | 45.58 | 45.77 | 0.42 |
| 15 | 39.05 | 39.42 | 0.95 |
| 16 | 38.22 | 38.28 | 0.16 |
| 17 | 43.23 | 43.88 | 1.50 |
| 18 | 46.34 | 46.49 | 0.32 |
| 19 | 45.59 | 44.84 | -1.65 |
| 20 | 46.21 | 45.96 | -0.54 |
| Average | 0.68 |
So on average for points that in both cases have a similar spatial situation the difference in calculated PET is 0.68%.
Setup
Weather data from weatherstation Herwijnen has been used for this test case. The used values are:
| Variable | Value |
| Date | 02-08-2013 |
| Hour of day | 14 |
| Sun altitude | 55.5 |
| Sun azimuth | 186.9 |
| Sun daily motion factor | 0.063 |
| Humidity (%) | 56 |
| Sun radiation (W/m2) | 774 |
| Temperature (°C) | 31.7 |
| Wind speed (m/s) | 4 |
| Wind direction (°) | 140 |
| Daily min. temperature (°C) | 18.9 |
| Daily max. temperature (°C) | 34.1 |
| Daily avg. radiation (W/m2) | 455 |
| Daily avg. wind speed | 3.17 |
The foliage height will be defined by a Geotiff. See the images (overview and zoomed in east-south-east corner) below:
Calculation time
The calculation time of the PET overlay of 1 timeframe on a 1x1 meter grid for a 4x4km area of Wageningen is +-16 seconds.
- A tutorial on how to obtain and interpret dutch weather station data
- For a more in depth variance analysis, see analysis;
