Diffuse radiation formula (Heat Overlay)
Revision as of 14:49, 11 September 2019 by Frank@tygron.nl (talk | contribs) (Created page with "The diffuse radiation is an input parameter for the PET-formula The diffuse radation Q<sub>d</sub> at time t is calculated using the following formula: Q<sub>d,t</sub> =...")
The diffuse radation Qd at time t is calculated using the following formula:
Qd,t = Qgl,t * ftransmission,t
where,
  • Qgl,t is the amount of sun radiation at time t, measured at a weather station.
  • ftransmission,t is the Atmospheric transmission factor at time t.
The atmospheric transmission factor is calculated as followed:
Factor Condition
1 τa <= 0.3
1.6-2* τa 0.3 < τa < 0.7
0.2 τa>=0.7 Flooding Overlay provides insight into water stress and impact caused by breaches in levees or other sources causing excessive water inflow
