UK EA benchmark 2 (Water Module)
This page contains the test case 2 of the UK benchmark named Test 2 – Depression filling as well as its results generated by the Water Module in the Tygron Platform.
The test has been designed to evaluate the capability of a package to determine inundation extent and final flood depth, in a case involving low momentum flow over a complex topography.
Description
Fig. a: Map of the DEM showing the location of the upstream boundary condition (red line), ground elevation contour lines every 0.05 m, and output point locations (crosses)
The area modelled, shown in Figure (a), is a perfect 2000 m x 2000 m square and consists of a 4 x 4 matrix of ~0.5 m deep depressions with smooth topographic transitions. The DEM was obtained by multiplying sinusoids in the North to South and West to East directions and the depressions are all identical in shape. An underlying average slope of 1 : 1500 exists in the North to South direction, and of 1 : 3000 in the West to East direction, with a ~2m drop in elevation along the North-West to South-East diagonal.
The inflow boundary condition is applied along a 100m line running South from the North Western corner of the modelled domain, see Figure (a).
A flood hydrograph with a peak flow of 20m 3 /s and time base of ~85mins is used. The model is run for 2 days (48 hours) to allow the inundation to settle to its final state.
Fig. b: Inflow hydrograph used as upstream boundary condition in Test 2
  • Inflow along the red line in Figure (a). Location and tables provided as part of dataset.
  • All other boundaries are closed.
  • Initial condition: Dry bed.
Parameter values
  • Manning’s n: 0.03 (uniform)
  • Model grid resolution: 20m (or ~10000 nodes in the area modelled)
  • Time of end: model is to be run until time t = 48 hours
Technical setup
The provided ascii height file named test2DEM.asc is first imported. It has a cell size of 2m, while the test is expected to run on a 20m grid. Therefore, it will be automatically rescaled by the grid rasterizer. Secondly, the area of interest is 2000 by 2000 m. The original dem had an offset of -200 meters, which we cropped down to -20 meters (1 grid cell), which we could use for the border cell. The rescaled and cropped .asc-file is packed in the down below.
  • Original 2m heightmap (2400m x 2400m)
  • Cropped and rescaled to 20m grid (2040m x 2040m). Border cells are in black.
  • Inlets in upper left corner
In order to regulate the water level according to the water level graph, we used the following setup: Inlet objects were placed on gridcells with x = 1 and y = 1 .. 5 , so 5 in total. Each inlet therefore has a single cell. The inlets were configured as:
  • External area (m2): 1 000 000 000;
  • Water level (m): 1;
  • Threshold (m): none;
  • Inlet Q (m) : 20 m3 /s in total, so 4 m3/s per inlet. The following image shows the inlet q with discrete steps.
Output as required
  • Software package used: Tygron Platform
  • Numerical scheme: FV (Kurganov, Bollerman, Horvath)*
  • Specification of hardware used to undertake the simulation:
    • Processor: Intel Xeon @2.10GHz x 8,
    • RAM 62.8 GiB,
    • GPU: 2x NVidia 1080
    • Operating system: Linux 4.13
  • Time increment used: adaptive:
  • Grid resolution: 10 m.
  • Simulation time:
  • Object flow: 96985.64 m3
  • Remaining volume water: 96982.30 m3
  • Graph of point 1 generated by the Tygron Platform on the left and generated by others on the right.
  • Tests are run with multi gpu setup. For small cases like this, running it on a single gpu is actually faster. Furthermore, requesting 576 timeframes further bogs it down.
In comparison: 1 gpu with 1 resulting timeframe runs in: 8 seconds, which is +- 53% faster compared to 2 gpu's with 576 timeframes.
