Water evaporation factor (Water Overlay)
Revision as of 09:27, 3 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "{| class="wikitable" ! Attribute ! Unit ! Function value ! Description |- |{{anchor|WATER_EVAPORATION_FACTOR_constructions|WATER_EVAPORATION_FACTOR}} |factor |Water evaporatio...")
Crops and foliage
Constructions representing crops and foliage can draw water from the underground, allowing it to evaporate. This behaves in the same way as terrain which is configured as plants.
=Notes
- When a construction is present in any given location, the values for evaporation will overrule any values set by terrain in the same location. To model underground evaporation without a construction, set these attributes on the applicable terrain type instead.
