Ground infiltration formula (Water Overlay)
Revision as of 13:04, 2 April 2019 by Frank@tygron.nl (talk | contribs) (Created page with "Underground infiltration (from the unsaturated zone to the saturated zone) is calculated per cell. First the height of the unsaturated zone is calculated. : ''H<sub>unsat</su...")
S = Wunsat/Hunsat
Δw = Cinf * S
Where:
Template:WaterOverlay nav
