Density indicators
Revision as of 15:18, 15 March 2019 by Godelief@tygron.nl (talk | contribs) (Created page with "{{learned|what the density indicators are|how the density indicators are calculated|how to adjust your project in order to make the indicator functional}} ==General== ===What...")
General
What are the Density indicators?
This indicator is useful for projects where for example:
  • one of the goals is to work on reaching a certain housing target
  • different spatial plans are compared in the 3D world
Indicator panel
Calculation
Score
The score is represented in a progress bar, with a scale from 0 to 100%. Determine if you want to calculate the absolute or relative score.
Additional configurations
For this indicator to function, an extra attribute has to be added to the Neighborhood in where the houses will be build and a new Global has to be defined to set the total housing target. Read below for the steps.
