Sight Distance Overlay
Revision as of 08:54, 30 October 2018 by Maria@tygron.com (talk | contribs)
What the Distance Sight Overlay is
File:Sight Distance overlay.jpg
This Distance Sight Overlay combines the Distance Zone as defined by constructions with the direct line of sight for these constructions. The distance zone is always a circle situated around the affected construction(s). The radius of this circle can be adjusted in the function value table.The Distance Sight Overlay becomes available for all stakeholders when added to a project.
File:Distance sight hover.jpg
The distance of the selected object which has a distance zone is displayed
When clicking on a specific location in the map, the hover panel gives additional information of the distance from the clicked location to the object which has a distance zone.
Adding and removing the Distance Sight Overlay
Template:Editor ribbon
How to add the Distance Sight Overlay:
  2. Select 'Overlays' from the ribbon bar
  3. Select the Distance Sight Overlay from the drop down menu
How to remove the Distance Sight Overlay:
  3. Select the Distance Sight Overlay from the list of active overlays on the left panel
  4. Select 'remove' from the bottom of the left panel
  5. Confirm the removal in the pop up confirmation message
