Sight Distance Overlay
Revision as of 13:03, 29 October 2018 by Maria@tygron.com (talk | contribs) (→What the Distance Sight Overlay is)
File:Sight Distance overlay.jpg
This Distance Sight Overlay combines the Distance Zone as defined by constructions with the direct line of sight for these constructions. The distance zone is always a circle situated around the affected construction(s). The radius of this circle can be adjusted in the function value table.The Distance Sight Overlay becomes available for all stakeholders when added to a project.
Adding and removing the Distance Sight Overlay
How to add the Distance Sight Overlay:
- Select in the editor 'Geo Data' from the ribbon
- Select 'Overlays' from the ribbon bar
- Select the Distance Sight Overlay from the drop down menu
How to remove the Distance Sight Overlay:
- Select the Distance Sight Overlay from the list of active overlays on the left panel
- Select 'remove' from the bottom of the left panel
- Confirm the removal in the pop up confirmation message
