Water Overlay
What are the Water Overlays
When creating a new project in the new project wizard, take into account the Advanced options. In this menu for example the AHN3 dataset can be selected, which, if available for your project area provides the most recent heightdata available as Open Data. Also, the IMWA dataset is already checked, this means that if available in your project area, Water Level areas and/or Culverts are already imported.
Configuration Wizard
Each of the Water Overlays has a configuration wizard which helps the user with configuring the overlay. The Configuration Wizard can be found in the General tab of the overlay. For the Flooding Overlay the wizard has an extra step, the Rainfall and Groundwater Overlay wizard are basically the same.
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
Result type | Unit | Description |
BASE_TYPES | nominal value | Division of gridcells in water, land or sewer areas that are connected to the sewer. |
CHLORIDE | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). | |
EVAPORATED | m (mm)¹ | Total evaporation over the simulation period |
GPU OVERVIEW | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). | |
IMPACTED_BUILDINGS | nominal value | Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M |
LAST SPEED | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). | |
MAX SPEED | m (below surface) | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). |
NITROGEN | m (below surface) | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). |
PHOSPHORUS | m (below surface) | Initial groundwater level relative to the surface level (NL: ontwateringsdiepte). |
SEWER_LAST_VALUE | m (mm)¹ | The amount of water in the sewer storage at the end of simulation |
SEWER_MAX_VALUE | m (mm)¹ | Maximum amount of water in the sewer storage during the simulation |
SURFACE_DURATION | s (min)¹ | The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M |
SURFACE_FLOW | m3/m2 | Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2) |
SURFACE_LAST_VALUE | m (min)¹ | Water depth at the end of simulation |
SURFACE_MAX_VALUE | m (min)¹ | Maximum water depth during the simulation |
UNDERGROUND_FLOW | m³/m² | Totall infiltration amount from the surface to groundwater |
UNDERGROUND_LAST_STORAGE | m (mm) | The amount by which the groundwater table has risen above the initial groundwater level at the end of simulation |
UNDERGROUND_LAST_VALUE | m (mm) | The amount by which the groundwater table has risen above the initial groundwater level at the end of simulation |
UNDERGROUND_MAX_STORAGE | m (mm) | The amount by which the groundwater table has risen above the initial groundwater level at the end of simulation |
UNDERGROUND_MAX_VALUE | m (mm) | The maximum amount by which the groundwater table has risen above the initial groundwater during the simulation |
UNDERGROUND WATERTABLE | m (mm) | The Maximum water depth during the simulation. At water cells only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M |
WATER_STRESS | m (mm) | The Maximum water depth during the simulation. At water cells only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M |
¹ the units between () are as displayed in the 3D client. If exported to GTiff the SI-convention is used: meters (m) and seconds (s).
General Tab
1. Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
- umax = max velocity, assumed 2.5 (SPEED), 5 (AVERAGE) and 10 (ACCURACY) m&sub3;/s respectively
2. Grid cell size
The Tygron Platform computes flow equations over a rectangular cartesian grid, the grid cell size can be set by cliking on Change Grid. Note: if you choose a smaller grid cell size, both the amount of time steps (see Calculation Preference) and amount of computational cells increase.
3. Refresh Grid
By Refreshing the grid, the Overlay is recalculated. This may take some time, depending on the grid cell size, the size of your project and the calcualtion preference.
4. Export Grid File
You can export the current result type as either a GeoTiff (binary file - bitmap image can be opened in a GIS or in an image viewer) or ASCII (text file, can also be opened in a GIS but is also readable in a text editor) file. Also, it is possible to export the difference result type of the current and maquette situation.
5. Save Overlay result
6. Show Water Balance
The Water Balance panel shows the in- and outflow of water in m3. The Water Balance panel is also visible when clicking on the Debug info (see below). The water balance is made up of the following components (dependent on what is in the project):
7. Warnings
When the grid cell size is too large in combination with the project size, a warning pops up. This means that calculated results are not accurate. The solution to this is to change the grid cell size to a smaller number.
8. Debug Info
- Water areas:
Keys
The tab Keys refers to the settings for the water system (areas and constructions) that are adjusted by following the configuration wizard in the General tab. It is therefore generally not needed to change the keys in this tab, as this can be done also in the configuration wizard. However, below an explanation of the Overlay Keys.
Attribute | Unit | Description |
Water Level | m + datum | initial water level, relative to datum, for all water cells in a water area |
Outlet | m3/s | water abstraction for all water cells in a water area |
Outlet level | m + datum | initial water level, relative to datum, for all water cells in a water area |
Outlet capacity | m + datum | initial water level, relative to datum, for all water cells in a water area |
Sewer Storage | m | available storage in sewers at the start of simulation in a sewer area |
Sewer Pump Speed | m3/s | sewer water abstraction for all cells in a sewer area |
Keys referring to structures (building attributes)
Weir Height | m + datum | weir crest level |
Weir Output | m | the width of the crest of a weir |
Weir Width | m | the width of the crest of a weir |
Weir Coefficient | linear weir coefficient for accounting discharge & contraction losses | |
Culvert Speed | m3/s | the discharge capacity of a culvert |
Pump Speed | m3/s | the capacity of a pump |
Sewer Overflow Height | m + datum | the height of a crest of a sewer overflow |
Sewer Overflow Speed | m3/s | the discharge capacity of a sewer overflow |
ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the water stress result type |
IMPACT FLOOD_THRESHOLD_M | m | maximum waterdepth around a building where after the building is assumed impacted |
MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
SIMULATION_TIME_HOURS | hours | simulation time |
