Flooding Overlay
What is the Inundation overlay
The inundation is developed for the computation of surface (water) flow in a wide range of applications. These applications include large scale inundations due to dike breaches and inundations at the bottom of hill-slopes. Therefore the commonly applied 2D Saint Venant Equations are implemented on a highly parallel applicable explicit numerical scheme suitable for Tygron GPU clusters.
Adding and removing
To add an inundation overlay go to the Overlays menu in the GEO DATA ribbon and select Add Inundation. To remove the overlay, press Remove below the overlays list.
File:Rainfall overlay 01.PNG File:Rainfall overlay 02.PNG
Result types
The rainfall overlay is a grid overlay showing results of heavy rainfall on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
Result type Unit Description
BASE_GROUNDWATER_DISTANCE m (below surface) Initial groundwater level relative to the surface level (NL: ontwateringsdiepte).
BASE_TYPES nominal value Division of gridcells in water, land or sewer areas that are connected to the sewer.
EVAPORATED m (mm)¹ Total evaporation over the simulation period
IMPACTED_BUILDINGS nominal value Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M
SEWER_LAST_VALUE m (mm)¹ The amount of water in the sewer storage at the end of simulation
SEWER_MAX_VALUE m (mm)¹ Maximum amount of water in the sewer storage during the simulation
SURFACE_DURATION s (min)¹ The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M
SURFACE_FLOW m3/m2 Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2)
SURFACE_LAST_VALUE m (min)¹ Water depth at the end of simulation
SURFACE_MAX_VALUE m (min)¹ Maximum water depth during the simulation
UNDERGROUND_FLOW m³/m² Totall infiltration amount from the surface to groundwater
UNDERGROUND_LAST_VALUE m (mm) The amount by which the groundwater table has risen above the initial groundwater level at the end of simulation
UNDERGROUND_MAX_VALUE m (mm) The maximum amount by which the groundwater table has risen above the initial groundwater during the simulation
WATER_STRESS m (mm) The Maximum water depth during the simulation. At water cells only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M
¹ the units between () are as displayed in the 3D client. If exported to GTiff the SI-convention is used: meters (m) and seconds (s).
Inundation Model
2D Saint Venant equations
The 2D Saint Venant equations describe the conservation of mass in a gridcell and the conservation of momentum in both x and y, direction:
The Saint Venant equations describe the following processes:
  • friction
  • bed slope
  • water pressure
Numerical scheme
The explicit second-order semi-discrete central-upwind scheme for the 2D Saint Venant Equations is implemented. A reconstruction of cell bottom, water level and velocity at the interfaces between computational cells as proposed by Lax and Wendroff (see Rezzolla, 2011). The Tygron Engine Inundation module relies on the scheme described in Kurganov and Petrova (2007). The reconstruction method is taken from Bolderman et all (2014) and ensures numerical stability at the wetting and drying front of a flood wave.
Inundation(Benchmarks)
Computation time step
An adaptive timestep is implemented according to Kurganov and Petrova (2007). At every timestep, the courant-number is kept smaller than 0.25 for every active computation cell:
Calculation Preferences (General Tab)
Overlay Keys
