EULA
The licensing terms here may be incomplete and/or out of date, and are placed here for reference only. For the current End User License Agreement, please find the EULA in the Tygron Engine, or Template:Support.
United States & Other
End-User USA and Other countries
Version: 2.0 (20180719)
These End-User Terms apply to you (the “End User”) as user of the Tygron Platform and the Client Application(s) of Tygron B.V. (“Tygron”). Upon installation of the Client Application, the End User declares to be bound by these End-User Terms.
Tygron is entitled to unilaterally amend these End-User Terms. Any new version of the End-User Terms must be re-confirmed by the End User prior to the further use of the Tygron Platform and the client Application(s). If the End User does not agree to the amendments, the End User must cease its use of the Tygron Platform and the Client Application(s).
Capitalised terms in these End-User Terms are defined as follows:
Administrator: the person assigned by the Licensee to manage the Domain on behalf of the Licensee
Client Application(s): the downloadable and/or web-based Tygron-application(s) used to gain access (through a password and username) to the Domain in order to use the Tygron Platform
Content: the data or particulars entered by the End User within the Domain
Domain: Domain: the closed environment within the Tygron Platform provided to the Licensee and in which End User(s) may enter Content and perform Editor or Impact Sessions
Editor Session: a session in which the End User individually edits a Loaded Project
End-User Terms: these terms, which are binding upon each End User with regard to the use of the Tygron Platform and the Client Application(s)
Impact Session: the session in which a Project – whether or not after an Editor Session – is used by one or more End Users
IP rights: intellectual-property rights, both registered and non-registered, including, however not limited to patent rights, copyrights (including rights to source and object codes), database rights, brand rights, rights related to knowhow and company secrets
Licensee: the party with whom Tygron has entered into an agreement for the use of Tygron Platform and the Client Application(s)
Loading: the start-up of a new Project in the Domain for application in an Editor Session and/or an Impact Session
Project: a geographic area within the Netherlands, whether or not supplemented with data and/or the Licensee’s personal settings
Saving: saving the Project after an Editor Session and/or an Impact Session, or keeping a Loaded Project active
Tygron Platform: the Tygron Engine server platform consisting of a combination of software and hardware (such as servers).
Article 1End-User Rights
In compliance with these End-User Terms, the End User uses the Client Application to gain access to the Licensee’s Domain in order to use the Tygron Platform.
The right obtained under section 1 is non-exclusive and non-transferrable and is obtained for the duration of the Licence between the Licensee and Tygron.
1.3The End User is not allowed, whether directly or indirectly:
a) to disclose, distribute, sell, copy and/or in any other way multiply the Tygron Platform and/or the Client Application(s);
b) to change or decompile the Tygron Platform and/or the Client Application(s), to multiply their code, to translate them or in any otherwise subject them to reverse engineering;
c) to use the Tygron Platform and/or the Client Application(s) for a purpose other than for the Editor Sessions and Impact Sessions;
d) (to cause) to disseminate viruses, worms, Trojan Horses, rootkits, spyware, hoaxes or other forms of malware;
e) to (try and) hack the Tygron Platform and/or the Client Application(s) and/or to (cause to) gain unauthorised access thereto in any other manner;
f) to change or remove any indication or referral in the Tygron Platform and/or the Client Application(s) to Tygron, Tygron’s exclusive IP rights, their confidential nature, or any other referral by Tygron.
1.4The End User shall furthermore warrant that no legislation or regulations or third-party rights are violated by any entered Content. This means that the End User must refrain from:
a) (causing) to leave behind or (causing) to disseminate information in contravention of the law, the generally accepted and applied ethics and care;
b) (causing) to delete or change data or make them ineffective or add data to the Client Application(s) or to automated systems, computers, databases or servers of Tygron or of third parties;
c) (causing) to delete, change or enter personal data of third parties – without permission or other legitimate basis;
d) (causing) to enter Content infringing IP rights or other statutory rights (such as privacy rights) of third parties.
1.5Tygron is entitled to the use of the Tygron Platform and/or the Client Application(s) by checking the End User as well as any results from the Editor Sessions and/or Impact Sessions for the limitations described in this Article.
1.6The End User is responsible for any activities taking place through the End User’s account. The End User shall observe secrecy with regard to any usernames, passwords and other access details under the terms of the Application and shall not disclose them to third parties. The End User must notify the Administrator and/or Tygron promptly once the End User has stated that a third party has gained unauthorised access to his account.
Article 2Verification of Use and Access Restriction
2.1 The End User is individually responsible for (i) using the appropriate hardware, which is actively connected to the internet in order to be able to use the Client Application(s). Tygron does not guarantee compatibility or the appropriate operation of the Client Application(s) in combination with all of the End User’s hardware or software. With respect to the appropriate operation of the Client Application(s), Tygron recommends using hardware, software and systems that meet the system requirements set down by Tygron. Tygron shall not at any time bear liability for any loss resulting from incompatibility of the End User’s hardware or software with the Client Application(s).
Tygron may at all times de-activate access to the Tygron Platform and/or the Client Application(s) (temporarily) or limit its use where necessary for maintenance purposes or for implementing updates, for releases, adjustments or improvements in the Tygron Platform and/or the Client Application(2).
Tygron reserves the right to stop certain calculations within a Project in case this causes limitation to the functionality of the Tygron Platform for other licensees or end users. Tygron shall not be liable for any resulting loss.
Tygron is authorised to verify (i) how the Tygron Platform and/or the Client Application(s) are used by the End User, (ii) the results obtained with the Impact Sessions and the Editor Session, (iii) the End User’s Content.
Tygron observes confidentiality in saving these data as referred to in Article 2.4 for at least the duration of the agreement with the Licensee and up to two years subsequently, subject to anonymised data, which may be retained longer for statistic purposes. Tygron shall only use the data: (i) for the improvement and updates of the Tygron Platform and/or the Client Application(s) and (ii) for the verification of compliance by the End User with the obligations from the agreement and these End-User Terms.
If the End User needs practical support with regard to the use of the Tygron Platform and/or the Client Application(s), the End User must contact the Administrator who gave the End User access to the Client Application(s) on behalf of the Licensee.
Article 3Intellectual Property Rights
3.1Any IP rights regarding the Tygron Platform, the Client Application(s) and any other services provided by Tygron shall be vested in Tygron and/or its licensors only. The End User shall only obtain a limited and temporary user right with regard to the use of the Tygron Platform within the Domain and under the terms of these End-User Terms.
3.2Third-party software and/or open-source software (jointly the “third party software”) are used for parts of the Tygron Platform and the Client Application(s). Referrals to such third-party software and/or relevant (licence) terms are adopted in the Tygron Platform and the Client Application(s). The use of third-party software is subject to the relevant (licence) terms, which can be provided by Tygron to the End User at first request.
3.3Tygron shall at all times be allowed to implement technical facilities for the protection of the Tygron Platform, the Client Application(s) (including the relevant IP rights) and/or the third-party software, even if this should cause a limitation of use. The End User shall not at any time be allowed to (cause to) remove or (cause to) circumvent such technical facility.
Article 4Disclaimer
4.1 Even though the Tygron Platform and the Client Application(s) have been compiled with utmost care, Tygron does not guarantee that the Tygron Platform and the Client Application(s) operate flawlessly and/or contain no faults. The Tygron Platform and the Client Application(s) are provided ‘AS IS’. Where permitted by law, Tygron dismisses any explicit or implicit guarantees including the implicit guarantee that the Tygron Platform and the Client Application(s) are suited for a certain purpose.
4.2Tygron does not provide any guarantees with respect to, and does not bear any liability for any loss resulting from: (i) the fact that the Tygron Platform and/or the Client Application(s) do not meet the End User’s expectations, (ii) the fact that the Tygron Platform and/or the Client Application(s) are not or not without any faults or without any interruptions available, (iii) the effectiveness, accuracy or reliability of the results obtained through an Editor Session and/or Impact Session, (iv) the Content entered by the End User, (v) the correctness and completeness of third-party data within the Tygron Platform.
Article 5Liability and indemnification
5.1Without prejudice to the other provisions in this Article, Tygron shall not, where permitted by law – bear any liability for any loss whatsoever suffered by the End User or any loss Tygron may be held liable for by third parties. Any liability on the part of Tygron, on any account whatsoever, shall at any rate be limited to a compensation of the direct loss, i.e. up to an amount of € 250.
5.2 Tygron shall in no case whatsoever bear any liability for any consequential loss, such as, however not limited to loss of income, loss of profits, loss of Content suffered by the End User as a result of his use of the Tygron Platform.
5.3Tygron shall not be bound by the fulfilment of any obligation, which is prevented by, or the compensation of any loss, which is the result of force majeure. Force majeure includes (i) government measures, (ii) electricity failure, (iii) internet failure, breakdown of the computer network or telecommunication facilities including internet providers and/or datacentres, (iv) war, (v) lock-in, (vi) strike, (vii) defective items, equipment, software or materials, which use has been requested by the Licensee, (viii) force majeure on the part of Tygron, (x) policy changes and/or the suppliers’ default in third-party software.
5.4The capacity of the Tygron Platform has been designed for a fair use by the Licensee of the Tygron Platform– as estimated by the Licensor. If the use of the Tygron Platform (whether or not due to peak loads) requires more capacity than estimated by the Licensor, the Licensor may (temporarily) block access to the Tygron Platform and the Client Application(s), which means that the Tygron Platform can (temporarily) not be used. Tygron is not liable for any resulting loss.
5.5The End User indemnifies Tygron and holds it harmless against any claims, demands, loss and/or costs resulting from or related to the use of het Tygron Platform by the End User, as well as the Content entered by the End User.
Article 6 Applicable Law and other Provisions
6.1 These End-User Terms are governed by Dutch law only.
6.2If any provisions of these Licence Terms are null and void or should be cancelled, the remaining provisions of these Licence Terms shall continue to be fully effective. Tygron and the Licensee shall in that case consult with each other in order to agree to new provisions for the replacement of the null and void or cancelled provisions, while the purpose and the purport of the null and void or cancelled provisions shall be as much as possible in keeping with the replaced provisions.
6.3Where Tygron opts for continuation of an infringement, Tygron shall not be considered to have in any way waived its rights on account of these Licence Terms. Tygron may in such case at any time assert its rights for reasons of its own.
Netherlands
End-User Conditions The Netherlands
Version: 1.4 (20170425)
Updated: Adreswijziging: Lange Voorhout 46
De Eindgebruiker is bij het gebruiken van de Programmatuur te allen tijde gebonden aan hetgeen Tygron heeft afgesproken met Licentienemer in de licentieovereenkomst. Het gebruik van de Programmatuur dient te geschieden binnen de voorwaarden zoals vastgelegd in die licentieovereenkomst. Indien de Eindgebruiker vragen heeft over het gebruik van de Programmatuur en de licentieovereenkomst dient de Eindgebruiker zicht tot de Licentienemer te wenden die aan de Eindgebruiker toegang heeft doen verschaffen tot de Programmatuur. De volgende voorwaarden zijn – onverminderd het voorgaande - van toepassing op de relatie tussen Tygron en iedere persoon die de Programmatuur van Tygron, die op de Server wordt gehost, gebruikt ter uitvoering van een Editorsessie en/of een Gebruikerssessie. De termen met een hoofdletter hebben de volgende betekenis:
App: de te downloaden applicatie waarmee (met gebruik van een wachtwoord en gebruikersnaam) een Sessie kan worden uitgevoerd.
Editorsessie: de Sessie waarbij Eindgebruiker zelfstandig een product of concept samenstelt of data verzamelt.
Eindgebruiker: de persoon die gebruik maakt van de Programmatuur.
Eindgebruikersvoorwaarden: deze voorwaarden.
Gebruiksgegevens: heeft de betekenis als bedoeld in artikel 4.3.
Gebruikssessie: de Sessie waarbij (i) een door Tygron samengesteld product of verzorgd concept wordt gebruikt (al dan niet ter vergaring van data) of (ii) een door Licentienemer zelfstandig samengesteld product of concept wordt gebruikt (al dan niet ter vergaring van data).
IE: heeft de betekenis als vermeld in artikel 3.1.
Licentienemer: de partij waarmee Tygron een licentieovereenkomst heeft afgesloten voor het gebruik van de Programmatuur en die van Tygron de exclusieve bevoegdheid heeft gekregen Apps te distribueren aan Eindgebruikers.
Programmatuur: de Apps en de software van Tygron die op de Server wordt gehost ter uitvoering van een Editorsessie en/of een Gebruikerssessie.
Sessie: het door een of meer Eindgebruikers (opnieuw) opstarten van de Programmatuur.
Server: de server van Tygron waarop Programmatuur gehost wordt.
Third Party Software: de third party software als bedoeld in artikel 3.2.
Tygron: betekent Tygron B.V. gevestigd op de Lange Voorhout 46, 2514 EG, Den Haag in Nederland.
Artikel 1 Kopiëren en vertrouwelijkheid
1.1 Eindgebruiker zal de Programmatuur niet openbaar maken en deze niet kopiëren en/of anderszins verveelvoudigen en/of distribueren.
1.2 Eindgebruiker zal eventuele gebruikersnamen, wachtwoorden en andere toegangsgegevens waarmee de Programmatuur kan worden gebruikt geheim houden en niet aan anderen verstrekken.
1.3 Het is Eindgebruiker niet toegestaan enige aanduiding of verwijzing in de Programmatuur naar Tygron, het exclusieve recht van Tygron op het (intellectuele) eigendom betreffende de Programmatuur, de identiteit van de makers van de Programmatuur, het vertrouwelijk karakter van de Programmatuur, of enige andere verwijzing door Tygron aangebracht in de Programmatuur, te wijzigen of te verwijderen.
1.4 Na beëindiging van de licentieovereenkomst zal Tygron de toegang tot de Programmatuur op de Server deactiveren.
Artikel 2 Reverse engineering en wijzigen
2.1 Het is Eindgebruiker niet toegestaan de Programmatuur te wijzigen, te decompileren, de code te verveelvoudigen en/of te vertalen of anderszins aan reverse engineering te onderwerpen.
2.2 Eindgebruiker staat er voor in dat bij en met het gebruik van de Programmatuur geen regelgeving van overheidswege of contractuele plicht jegens Tygron of een derde wordt geschonden. Dit houdt onder andere in dat Eindgebruiker bij het gebruik van de Programmatuur zich onthoudt van:
a. het (doen) verspreiden van virussen;
b. het in de Programmatuur (doen) achterlaten of (doen) verspreiden van informatie die in strijd is met de wet, de goede zeden en de maatschappelijke zorgvuldigheid;
c. het (doen) hacken en/of het op enige andere wijze ongeautoriseerd toegang (doen) verschaffen tot (en/of manipuleren van) de Server;
d. het zich zonder toestemming toegang (doen) verschaffen tot geautomatiseerde systemen, computers, databases of servers van derden;
e. het (doen) wissen, veranderen, onbruikbaar maken van of gegevens toevoegen aan de Programmatuur, Server of aan geautomatiseerde systemen, computers, databases of servers van derden.
2.3 Tygron heeft het recht het gebruik van de Programmatuur door Eindgebruiker en de producten voortvloeiende uit de Gebruikssessies en de Editorsessies te controleren op de hiervoor beschreven uitgesloten handelingen.
Artikel 3 Intellectuele Eigendomsrechten
3.1 Alle rechten van intellectuele eigendom betreffende de Programmatuur en de producten, concepten en data die resulteren uit een gebruik van de Programmatuur (het “IE”) berusten bij Tygron. Eindgebruiker verkrijgt uitsluitend een beperkt gebruiksrecht.
3.2 Onderdelen van de Programmatuur maken gebruik van software van derden en/of open source software (gezamenlijk de “Third Party Software”). Verwijzingen naar dergelijke Third Party Software en/of bijbehorende (licentie)voorwaarden zijn opgenomen in de Programmatuur. Het gebruik van de Third Party Software is onderworpen aan de desbetreffende licentievoorwaarden. Op verzoek kan Tygron meer informatie over de Third Party Software verstrekken.
3.3 Het is Tygron te allen tijde toegestaan technische voorzieningen aan te brengen ter bescherming van de Programmatuur, het IE en/of de Third Party Software. Het is Eindgebruiker nimmer toegestaan een dergelijke technische voorziening te (laten) verwijderen of te (laten) omzeilen.
Artikel 4 Updates, verbeteringen en Gebruiksgegevens
4.1 Ondanks dat de Programmatuur met grote zorg is samengesteld, garandeert Tygron niet dat de Programmatuur foutloos werkt en/of zonder omissies is. Tygron streeft er voortdurend naar om gebreken in de Programmatuur zo spoedig mogelijk op te lossen. Voorts garandeert Tygron niet dat de Programmatuur geschikt is voor het doel dat Eindgebruiker beoogt.
4.2 Tygron kan te allen tijden automatische updates en veranderingen in de Programmatuur doorvoeren of aan de Programmatuur toevoegen om het functioneren van de Programmatuur te verbeteren. Tygron streeft ernaar dat de implementatie van updates foutloos geschiedt, maar kan de compatibiliteit van de Programmatuur na een update met toepassingen, waaronder hardware, software of systemen van Licentienemer en/of Eindgebruiker, gedateerd voor de update niet garanderen.
4.3 Tygron is bevoegd (i) de wijze waarop Eindgebruikers gebruik maken van de Programmatuur, (ii) de met de Gebruikssessies en Editorsessie verkregen resultaten en/of (iii) de identificatiegegevens van de Eindgebruikers (de “Gebruiksgegevens”) te registreren en te bewaren. Tygron bewaart de Gebruiksgegevens vertrouwelijk voor ten minste de duur van de overeenkomst met Licentienemer en tot een jaar daarna. Tygron wendt de Gebruiksgegevens slechts aan (i) ter verbetering en actualisering van de Programmatuur, en (ii) controle op de naleving door Licentienemer en/of Eindgebruikers van de verplichtingen voortvloeiende uit de overeenkomst met Licentienemer en deze Eindgebruikersvoorwaarden.
Artikel 5 Aansprakelijkheid
5.1 Onverminderd de overige bepalingen in dit artikel 5 is Tygron niet aansprakelijk voor schade in welke zin dan ook die Eindgebruiker lijdt of waar Tygron door derden voor aansprakelijk wordt gehouden, tenzij de schade het gevolg is van opzet of bewuste roekeloosheid van Tygron.
5.2 Tygron is niet gehouden tot het nakomen van enige verplichting die verhinderd wordt door, of de vergoeding van enige schade die het gevolg is van, overmacht. Onder overmacht wordt mede verstaan (i) overheidsmaatregelen, (ii) elektriciteitsstoring, (iii) storing van internet, computernetwerk- of telecommunicatiefaciliteiten, (iv) oorlog, (v) werkbezetting, (vi) staking, (vii) algemene vervoersproblemen, (viii) de gebrekkigheid van zaken, apparatuur, programmatuur of materialen waarvan het gebruik door Licentienemer is verzocht, (ix) overmacht van toeleveranciers van Tygron, (x) het niet naar behoren nakomen van verplichtingen van toeleveranciers die door Licentienemer zijn aangedragen.
5.3 Voorts vervalt iedere aansprakelijkheid van Tygron en de mogelijkheid om van Tygron schadevergoeding te vorderen indien Tygron niet is ingelicht over de feiten die aanleiding hebben gegeven tot de schade onmiddellijk doch in ieder geval niet later dan 5 dagen nadat deze feiten bekend waren, ook indien toen nog niet duidelijk was dat deze feiten tot schade zouden kunnen leiden. De mogelijkheid om van Tygron een schadevergoeding te vorderen vervalt voorts indien de feiten die aanleiding hebben gegeven tot de schade tijdig aan Tygron bekend zijn gemaakt, doch de vordering tot schadevergoeding niet binnen 12 maanden nadat de schade zich heeft voorgedaan in een juridische procedure aanhangig is gemaakt.
5.4 Tygron is voorts niet aansprakelijk voor de wijze waarop de resultaten van een Editorsessie en/of een Gebruikerssessie worden geïnterpreteerd en/of geïmplementeerd. Eindgebruiker vrijwaart Tygron voor eventuele aanspraken van derden in verband met het gebruik van de Programmatuur door Eindgebruiker en/of de eventuele resultaten van de Gebruikerssessies en de Editorsessies en/of de Gebruiksgegevens ten gevolge van het gebruik van de Programmatuur door Eindgebruiker.
5.5 Tygron is niet aansprakelijk voor geleden schade als gevolg van het niet of beperkt kunnen gebruiken van de Programmatuur als gevolg van interne en externe storingen, onderbrekingen bij Tygron en/of derden van enige verbinding, storingen van het internet of bij providers, of tekortkomingen van andere derden.
5.6 De capaciteit van de Server is ingericht op een redelijk – en het door Tygron geschatte – gebruik van de Programmatuur door Eindgebruiker. Indien het gebruik van de Programmatuur (al dan niet door piek belasting) meer capaciteit van de Server vergt dan door Tygron ingeschat, kan dit de toegang tot de Server blokkeren waardoor het gebruik van de Programmatuur niet mogelijk is. Tygron is niet aansprakelijk voor de eventuele schade die dit tot gevolg heeft. Tygron is bevoegd technische voorzieningen te implementeren ten einde overbelasting van de Server tegen te gaan, waaronder de mogelijkheid om Eindgebruiker de toegang tot de Programmatuur te ontnemen.
5.7 Eindgebruiker is verantwoordelijk voor gebruikmaking van de juiste hardware, die actief is verbonden met het internet, ten einde gebruik te kunnen maken van de Programmatuur. Tygron garandeert niet de compatibiliteit of de juiste werking van de Programmatuur in combinatie met alle hardware. Voor een juiste werking van de Programmatuur adviseert Tygron gebruik te maken van hardware en systemen die voldoen aan de systeemeisen zoals beschreven op de website van Tygron. Tygron is echter niet aansprakelijk voor schade als gevolg van incompatibiliteit van hardware met de Programmatuur.
Artikel 6 Toepasselijk recht en geschillen
Iedere overeenkomst tussen Eindgebruiker en Tygron wordt exclusief beheerst door het Nederlands recht. Geschillen tussen Eindgebruiker en Tygron worden exclusief voorgelegd aan de bevoegde rechter in ’s-Gravenhage.
