Traffic Noise Overlay
What is the Traffic Noise overlay?
The Traffic Noise overlay is an Overlay which displays the impact of traffic noise in different colors for the project area. These colors indicate traffic noise ranges from 0 dB to 75+ db. Based on traffic flow and distance a grid is calculated for the project area.
Adding and removing
Adding and removing overlays is a generic process, however, certain overlays are dependent on other assets being present too, such as indicators, terrains, vacancy, images, etc. For more information please refer to the respective main articles for the specific overlays.
- Select in the editor '3D World' from the ribbon
- Select 'Overlays' > 'Edit overlays' from the ribbon bar
- Select the Traffic Noise overlay from the drop down menu on the bottom of the left panel
- Select 'Add' from the bottom of the left panel
- The overlay icon will now appear under the mini map
1. Select 3D World
2. Select Overlays > Edit overlays
3. Select desired overlay from drop down menu on the bottom of the left panel
4. Select 'Add' from the bottom of the left panel
5. The overlay icon will now appear under the mini map
- Select the desired overlay'*' from the list of active overlays'**' on the left panel
- Select 'remove' from the bottom of the left panel
- Confirm the removal in the pop up confirmation message
1. Select 3D World
3. Select desired overlay from the list of active overlays on the left panel
4. Select 'Remove' from the bottom of the left panel
5. Confirm the removal in the pop up confirmation message
Sometimes it can be convenient to duplicate an already existing overlay. To do so, follow the steps for removal, but select 'Duplicate' in stead of 'Remove'.
The overlay calculations are based on Standard Calculation Method 1 (SRM1) as defined by the dutch government: wetten.overheid.nl
