Net Line
Revision as of 13:01, 24 October 2017 by Rudolf@tygron.com (talk | contribs)
This article is a stub.
What are net lines
A line, in network simulation terms, is a connection between different nodes in a resource transport and distribution network. Along with the nodes of the network they form a graph.
How net lines relate to the Tygron Engine
In the Tygron Engine, lines and nodes, along with net loads, form distribution networks. They are defined by 2 nodes, a starting node and an end node, and a net line definition.
Restrictions on networks
  • Networks cannot contain any cycles. All networks should be defined as a tree.
  • A net node can be connected to 1, 2, or more net lines, except when that node is a load node.
