Attribute
What is an Attribute?
An attribute is a characteristic of a particular component in the 3D world like an areas or a construction. An attribute is always a number and can have a positive or a negative value.
Attributes in relation to the Tygron Engine
Attributes contain information about a particular component which can be used in Excel calculations. The value of an attributed can be changed as a result of an Excel calculation or as the result of an event. Some of the attributes and their value at the start of the project are added by default. It is also possible to add or adjust attrubites and the value manually. In addition, there is also the possibility to import attributes as part of importing GeoJSON files. The Engine's component where attributes are applied to are: neighborhoods, areas, constructions and zones.
The attribute is always described as number value. When the attribute is not given as a number the outcome of a calculation will be zero. But it is also possible that the legit outcome of a calculation is zero. Therefor, when the outcome is zero it can be wise to check the spreadsheet for errors.
When you want to make use of an attribute in an Excel indicator you need to specify in the spreadsheet if the attribute is included int the calculation or not. This is done by the ACTIVE attribute. For the ACTIVE attribute the input is always 1 for active and 0 for not active.
How to add and remove attributes
Attributes can be added for neighborhoods, areas, constructions and zones. In order to add an attribute for one of these Engine components you need to first open the panel of the particular component.
- To add new attributes, open the Attributes tab on the right in the selected Engine component.
- To select the attributes you want to import with a GeoJSON file, choose the right attribute name.
- It is not possible to remove a single attribute. You can only remove all attributes at once.
- Enter a new attribute name
- Enter a value
- Select "Save New Attribute".
- Select the GeoJSON file in the folder
- Drag and Drop the file in the Tygron Engine
- Select the desired input
- Make sure the attribute checkbox is checked
- Select the right attribute name
- Select the right attributes to import
- Select Send to import the attributes together with the imported area.
- To remove all attributes at once select "Reset Variables".
Edit attributes
Normally it is not necessary to adjust the values of attributes.
Active (by default)
- When an attribute is active it will be taken into account when the .
Color (by default)
Rudolf will explain the color
Add new Attribute with Name
- This is the name of the attribute. This name will be used in the query language and can not be adjusted after selecting Save New Attribute.
Add new Attribute with Value
- This is the value of the new added attribute. This value can be adjusted after selecting save New Attribute.
Reset variables
- When selecting this function all attributes are removed from the right attribute tab.
