How to add an Attribute
Revision as of 13:15, 30 January 2024 by Frank@tygron.nl (talk | contribs)
![](/w/images/c/c8/Attribute_editing_panel.jpg)
The right panel allows you to add new attributes. The top half displays existing Attributes, the bottom half allows you to add new Attributes.
Many things in a Project, ranging from Stakeholders to Overlays to Buildings, have Attributes, allowing generic properties to be configured for them. For most kinds of data, Attributes can be added and edited in a similar fashion.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an attribute:
- Select the type of data to add an Attribute to.
- Switch to the "Attributes" tab.
- Scroll to the bottom of the right panel, if neccesary.
- For "Add new Attribute with name", enter the desired TQL name name.
- For "Add new Attribute with value", enter the desired value.
- Click on "Save new Attribute".
- The Attribute has now been added.
