Bridge elevation (Water Overlay)
Revision as of 14:50, 29 January 2024 by Frank@tygron.nl (talk | contribs)
![](/w/images/1/17/Wateroverlay_wizard_bridge_elevation.png)
Bridge elevation can be configured in Structure Settings step of a Water Overlay wizard.
Icon | Attribute | Unit | Range | Description | Default value |
BRIDGE_ELEVATION | nominal | Specifies the mode by which bridges are include in the elevation model, used for the water calculations. | Lowest |
0. | Lowest: Lowest elevation point from Terrain below bridge is used. |
1. | Terrain: Use standard elevation from Terrain. Bridges are excluded from the DEM, allowed water to flow as if they didn't exist. |
2. | Bridge : Use bridge deck as elevation. Bridges and floating Constructions are included in the DEM, blocking water flow. |
- When using Bridge mode, it is still possible to model the flow from one side of a bridge to the other by using a Culvert.
