How to edit network specific settings
Revision as of 13:12, 17 February 2023 by Frank@tygron.nl (talk | contribs) (Created page with "This how-to describes how to edit network-specific settings frame|right|The right panel for settings specific per network. {{Editor location|networks|Any specific network type}} '''Active''' : ''Whether this network should be considered as a relevant network by the validation tools.'' '''Net Owner''' : ''Which stakeholder owns the network.'' '''Transport Attribute Name''' : ''The name of the attribute indicating the resource in...")
Editor → Current Situation (Ribbon tab) → Networks (Ribbon bar) → Any specific network type
Active
Net Owner
The name of the attribute indicating the resource in all components of the network.
Root, Loads, and Lines with Attribute
The amount of components which are currently an active part of the network, over the amount of components available in total for the network.
Net Setting
