How to configure the names of features created by a Geo Plugin
Revision as of 13:19, 12 January 2023 by Frank@tygron.nl (talk | contribs)
This how to describes how you can configure the naming convention of a Geo Plugin. There are ways the name is determined, in this sequence.s:
- Unique name per feature based on attribute of that feature
- Name specified for the Geo Link that is matched to feature.
- Name specified for the Geo Plugin adding the feature.
Unique name attribute
How to set up a name attribute used by an Area Geo Plugin to name features:
- Ensure a Project Source is set up from which the relevant Areas can be obtained.
- Open the overview for Geo Plugins.
- At the bottom of the left panel, select the AREAS type and select "Add".
- Select the newly created Geo Plugin.
- In the right panel, click on the source's "Select", and select the Project Source which relates to the desired source, for example GeoJSON.
- Configure the layer (if applicable for the specified Project Source). Configure the Attribute for the name.
- The name attribute for features used by the Geo Plugin is now configured.
Name based on Geo Link
How to set up a geo link used by an Area Geo Plugin to match and name features:
- Select the tab "Geo Links"
- Click add to add a new "Geo Link", and select it in the list. A new Bottom Panel opens.
- In the "General" tab, adjust the name specified in the field next to the "Name" label.
- The name for features matched to that Geo Link, that is used by the Geo Plugin, is now configured.
Note: When there is only Geo Link with no further specific matching attributes, all features will be matched to that geo link, causing each feature to receive this name, unless the Geo Plugin has also specified an existing name attribute. This name attribute always takes precedence.
Name based on Geo Plugin
- Configure the name of the Geo Plugin using the name field.
- The fallback name for added features used by the Geo Plugin is now configured.
