How to edit an Attribute
Revision as of 09:21, 12 June 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "thumb|The [[right panel allows you to add new attributes. The top half displays existing Attributes, allowing you to edit them.]] Many...")
The right panel allows you to add new attributes. The top half displays existing Attributes, allowing you to edit them.
Many things in a Project, ranging from Stakeholders to Overlays to Constructions, have Attributes, allowing generic properties to be configured for them. For most kinds of data, Attributes can be added and edited in a similar fashion. Attributes can be freely and easily edited.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to add an attribute:
  1. Select the type of data to change an Attribute of.
  2. Switch to the "Attributes" tab.
  3. Scroll to the Attribute you want to change, if neccesary.
  4. Change the listed Attribute value to the desired value.
  5. The Attribute has now been changed.
  • Adding an Attribute which already exists will change the existing Attribute value to the new value.
