How to remove an Attribute
Revision as of 09:12, 12 June 2020 by Rudolf@tygron.nl (talk | contribs) (Created page with "thumb|The [[right panel allows you to add remove Attributes. The top half displays existing Attributes, along with the option to remove them....")
File:Attribute remove.jpg
The right panel allows you to add remove Attributes. The top half displays existing Attributes, along with the option to remove them.
Many things in a Project, ranging from Stakeholders to Overlays to Constructions, have Attributes, allowing generic properties to be configured for them. For most kinds of data, Attributes can be added and edited in a similar fashion. After adding user-defined Attributes, those Attributes can be removed again as well.
Editor → The type of data to edit (Ribbon bar) → The data to edit (Left panel) → Attributes tab (Right panel)
How to remove an attribute:
