Weir (Water Overlay)
Revision as of 13:31, 17 October 2019 by Frank@tygron.nl (talk | contribs)
Template:Overlay attribute
- If a weir is placed in a waterway, and the waterway is not otherwise interrupted, water will be able to flow past the weir via the waterway itself. It is recommended to make sure that the waterway is obstructed by an increase in the terrain height in such a way that the only way water can flow from the one end of the weir to the other is via the weir.
